Drag Racing Tech
Front Fender Mod?
Old Aug 9, 2008 | 09:57 PM
SlickVert's Avatar
Default Front Fender Mod?
Front Fender Mod?
Has anyone had any issues after cutting lighten holes or cutting the whole area out of the outer front fenders?
Trying to decide what to do.
Thanks Bob
Old Aug 9, 2008 | 10:55 PM
1SlowFormula's Avatar
I have no problems with mine, but then again I don't take it on the street very often. I think the biggest issue is if you are involved in a front end collision, otherwise it will hold up just fine...
Old Aug 9, 2008 | 11:12 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Most people cut out the whole chunk. I cut out parts of mine.
Old Aug 10, 2008 | 08:29 AM
CanuckSS's Avatar
No Problems here. I removed the whole outer piece with a spot weld drill. The lower piece above the front wheel/tire I hole sawed. It seems like their is still lots of strength.
Old Aug 10, 2008 | 01:14 PM
2002_Z28_Six_Speed's Avatar
Did you weight the removed matl? Just interested in what the result was...
Old Aug 10, 2008 | 02:29 PM
studderin's Avatar
anyone have a fender crack without it. I cant remeber fully, there is a gap. But dosn't the fender flex in a little, then bottem out on the metal when you lean into it?
Old Aug 10, 2008 | 02:40 PM
BAKED's Avatar
I cut the whole thing out. I drive mine on the street a little bit and I haven't had any problems.
Old Aug 10, 2008 | 05:14 PM
OWN3D BY MY PROF!
1.25 lbs. I wish I would have cut the whole piece off, but I had already put the fenders back on and realigned them.
Old Aug 11, 2008 | 07:47 PM
I cut mine out completely, and it weighed in at just over 3.5# removed, but every little bit helps...
http://www.1slowformula.com/images/weight_reduction.jpg
http://www.1slowformula.com/images/w...reduction1.jpg
http://www.1slowformula.com/images/w...reduction2.jpg
