Drag Racing Tech
adjustable sway bar
Old Aug 15, 2008 | 10:03 PM
BigDB's Avatar
Default adjustable sway bar
how does an adjustable sway bar help at the track?
Old Aug 16, 2008 | 05:39 PM
96LT1355Z28's Avatar
If your reffering to a rear drag bar it holds the rearend level under the car, the rear wants to twist (up on pass side, down on dr side) as you accelerate. This looks like, and can be mistaken for mad torque on some cars. The endlinks transfer the twisting motion into the solid bar holding the rear end level under the car so the tires have equal traction. (kinda like a big a$$ swingarm).
Old Aug 16, 2008 | 08:36 PM
BigDB's Avatar
I guess I should have asked how to adjust it when the body is twisting. Would I tighten up the passenger side to keep it from unloading the tire on that side?
Old Aug 17, 2008 | 03:17 AM
If it appears as if the body is twisting to the passenger side (which it should) then yes, tighten up the passenger side. Only preload the sway bar a very small amount at a time.
Old Aug 18, 2008 | 10:25 PM
BigDB's Avatar
does the axle not twist the opposite direction as the body? if the passenger side tire is unloading wouldnt the drivers side need tightening (pulling it up) and the passenger side let out to (pushing the axle down) to keep the axle flat under the car. Am I thinking backwards here?
Old Aug 19, 2008 | 12:08 PM
1BADAIR's Avatar
if the car is rolling over on the right rear then make that link longer
Old Aug 19, 2008 | 05:58 PM
As stated by 1BADAIR legnthen the passenger side. My post was kinda confusing now that I read it again. By tighten up I meant legnthen.
