Drag Racing Tech
16" or 17" DR's?
Old Aug 19, 2008 | 10:00 PM
01redws6ta's Avatar
Default 16" or 17" DR's?
I am looking into a set of DR's to hook up at the track. I was wondering if I should go with 17" (275's) ones and put them on my stock rims or 16" ones and get a pair of take off rims (255's). Would the 16" ones be better due to more sidewall? I am also planning on removing the front sway bar. I had a lot of wheel spin last time and a 2.5 60'!
Any input would be appreciated.
Old Aug 19, 2008 | 10:36 PM
BadBandit69's Avatar
I would lean towards the 16's just cause they are lighter and cheaper. Take offs can be had pretty cheap. The tires are cheaper. Plus they only last like 6 or 7,000 miles on the street. So you don't want to be drivin on them all the time if its ur DD. Unless your lookin at nittos they seem to last longer and have better street manners.
Old Aug 19, 2008 | 10:53 PM
7420NW7TH's Avatar
I would say so. I'd go with the 16's.
Old Aug 20, 2008 | 01:04 AM
SOLO Z's Avatar
^x2 go with the 16's
Old Aug 20, 2008 | 09:33 AM
Bitemark46's Avatar
As stated above. 16". They have more sidewall than the 17's so you'll be able to "hit" the tires harder. -Mark
Old Aug 20, 2008 | 11:10 AM
3DFORMULA's Avatar
I agree with doing 16". It took a great TA before I could get good hook out of my 17" but it still inconsistent.
Old Aug 20, 2008 | 11:53 AM
omcar's Avatar
16s all the way...
Old Aug 20, 2008 | 12:48 PM
Dave J's Avatar
if you are getting rims for drag only use why not get 15`s?
Old Aug 20, 2008 | 01:58 PM
troopercar's Avatar
what he said^
but if you have stock 16's they are better than 17's as stated
Old Aug 20, 2008 | 05:46 PM
DopeFedZ's Avatar
The 16's should work. Shortly after buying a set of 315/45/16's my crap broke so I haven't even been able to try them out yet.
Old Aug 20, 2008 | 08:44 PM
01redws6ta's Avatar
Thanks for all the input guys...it sounds like the 16's are the way to go. My car is definately not a DD...I have put about 500 miles on it each of the last few years.
I know 15's would probably be best, but I don't want to hack up my brake calipers for clearance.
Now I'll just have to find some take off rims.
Old Aug 20, 2008 | 10:29 PM
3DFORMULA's Avatar
Originally Posted by DopeFedZ
Thanks pal! I had NO chance to make it to the bathroom before I creamed my shorts.
THATS BEAUTIFUL!
Old Aug 20, 2008 | 10:43 PM
Dragwheelz.com's Avatar
If your going to buy some take off rims, Don't bother as the width of the wheel is not that also.
go with the new F body Street light, 15x10 7.5" of back space. No grinding needed at all on the rears.
if you go into the wheel section there are a few threads, along with Pictures.
Old Aug 21, 2008 | 06:52 AM
JL ws-6's Avatar
Race your car!
15 inch rim and don't look back. Save yourself the headaches and go that route right away.
And if they're for track use only, don't screw around with the et tires, hell unless you have to run the radial for a class/rules I wouldnt' even do that, the et drag/full slick, just work... they have for years and that hasn't changed at all.
Radials can work, but if the suspension isn't right, you're gonna have to make it right. If the radial spins, it won't recover, bias ply slick, if it spins, it's only gonna for a foot or so then it's gonna grab, something the radial won't do.
For a starting point, bias ply full slick on a 15 inch rim, and go from there. You won't regret it.
