Drag Racing Tech
Times to expect
Old Aug 20, 2008 | 10:10 PM
SCREAMIN01SS's Avatar
Default Times to expect
What kind of times could I expect with approx 500 RWHP at stock weight. After I bolt on the Ati Procharger I will get it dynoed and have exact numbers. I just want to start planning for safety equipment , i.e. rollbar, 5 point harness etc. in the event I actually run 11.49 or below. I will have MT Et Streets in 15inch rims with 4.11s. I just need an estimate plase and thank you
Old Aug 20, 2008 | 10:39 PM
bigblock4-speed's Avatar
um.. 10.80-11.00's.. Just depends on how well the car is set up.
Old Aug 23, 2008 | 03:06 PM
mike#9's Avatar
I would think that you should run very bottom 11's......if the car is setup the way a 500hp car should be to run down the track............the car should go 10's like previously stated. Max effort could go to mid 10's.
Old Aug 23, 2008 | 05:59 PM
JDP's Avatar
JDP
my formula with stock everything (suspension, rear end, wheels, ect.) other than a built T56 and a 505rwhp 402 went 11.20 at 126 on a nitto drag radial, so thats ***** footing it out of the whole and everything, if your car is set up right, there is no reason not to go into the 10s
Old Aug 23, 2008 | 07:13 PM
what is the best suspension upgrades to do?
Old Aug 23, 2008 | 10:33 PM
mike#9's Avatar
That is relative to how far you want to go with the car....i.e desired e.t., driveability, etc.
Old Aug 24, 2008 | 07:23 PM
Im looking for a weekend type car that cane be driver on the road but then handle 500hp on a track
Old Aug 24, 2008 | 07:59 PM
jmill96Z's Avatar
I think you'll see bottom 11's @ 121 ish. Full weight is what's going to kill you. You might sqeak into the 10's with some good air.
Old Aug 24, 2008 | 09:46 PM
thats cool, im not tring to set records I want a car that makes for a sweet cruzer but can run decent at a track. Im mainly asked for times so i can get the safety equipment I need. Dont want to show up at a track just to get kicked out cause of equipment.
