Drag Racing Tech
Weight questions
Old Sep 1, 2008 | 04:54 PM
JUICED96Z's Avatar
Default Weight questions
Anyone remove the E-brake on street cars?
Car is driven very short distances and maybe 100 miles a year.
If so how much weight is all of it?
ALso need help on guessing the weight of my car when its back together.
83 Z
TH-400/12 bolt, monocaque (sp?) wheels, molly k-member and a-arms, molly 10 point, race carpet, Kirkey seats, all not needed brackets removed (not much weight but lets th ecarpet lay nicer), no radio or speakers, removed all not needed wiring, BBC with aluminum heads and intake, iron block, no HVAC, glass hood, removed whiper motor and whiper blades (heavy sucker for what it is), optima batter, ect ect.
Options- t-tops, full power, GFX.
Just looking for a rough number, I have no idea.
Thanks.
Old Sep 2, 2008 | 04:19 AM
InsaneAuto86's Avatar
Yup, It is pretty heavy.... 10-15#
Old Sep 2, 2008 | 11:01 AM
Steve Burger's Avatar
LS1TECH Sponsor
I would agree. The Cable and Handle are heavy.
Old Sep 3, 2008 | 04:10 AM
Originally Posted by Beaflag VonRathburg
Emergency Brake System = 12.125lbs
From the LT1 section...
Old Sep 3, 2008 | 04:20 AM
james562's Avatar
Cables themselves were 8-10lb I removed all the ebrake junk off the rear as well, between cables, ebrake pads, and handle it was around 13-15lbs
Old Sep 3, 2008 | 11:05 AM
Stroked96Bowtie's Avatar
Go here:
http://www.catscale.com/
See if you can find one near you. Its where me and my buddies go to wiegh our cars when we make changes. They charge $8.50 per weigh-in around here and give you a print out. Cant beat the accuracy
Old Sep 3, 2008 | 08:50 PM
JUICED96Z's Avatar
I have allways heard the truck scales are not that acurate for cars????????
Anyone have an idea at what weight I am looking at for the car?
Ill ditch the e-brake.
Still pulling wiring, a lot of it!!!!!! and its not like it was a ABS/EFI car!!!!
Old Sep 3, 2008 | 09:16 PM
Originally Posted by Stroked96Bowtie
Go here:
We've got a Feed/Lumber Store out this way that does not charge. Just pull up, get a digital reading, and be on your way...
