Need some help removing dash. PLEASE!
Having the Helms helped BTW. I am sure you have found most of the screws, but there are more.
Remove the glove box, all the under dash panels, remove knee bolsters [L & R], lower steering column, remove radio, remove instrument cluster, remove hvac controls, remove side air ducts, remove console, remove a-pillar moldings, remove dash trim pad, remove fuse block bolt, remove fuse block, remove data link bolts, cut tie strap [buried way the hell behind the dash], remove the air distributor ducts [bolts are GD hard to locate without a picture, as I recall there only one of them hidden near left of center at about arms length as accessed from the top], cuss like a sailor, do not forget where all the bolts/screw came from, and look for some bandages.
I got it this far down but had not real reason to remove it completely, as I had done all I had set out to do. It still looked like a total PITA to go any further without doing something more with the steering column. Unbolted it was still very much in the road.
Thanks again.
