Drag Racing Tech
DR newbie...have dumb question
Old Sep 8, 2008 | 08:28 PM
01redws6ta's Avatar
Default DR newbie...have dumb question
Well, I did a search and didn't come up with the answer to my simple question, so I'll ask you guys for a little help.
I got my pair of M/T ET Streets today and mounted them on my 16x8 camaro wheels. I was wondering what a good tire pressure starting point would be when I go to the track. They are 255/50R16's and my car is a 6 speed (see sig.). This is my first time running drag radials, so any input would be appreciated.
Old Sep 8, 2008 | 08:31 PM
tator98ta's Avatar
I could be wrong but i'm pretty sure most people run about 20psi on radials...Someone correct me if i'm off.
Old Sep 8, 2008 | 09:03 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
There are mutiple threads on this topic, do a search and you'll find results. Opinions will vary based on power, track conditions, suspensions, etc. I've gotten 1.5X 60 foots on 17-18 psi, I believe Gators99TA has gone 1.39 on 22 psi.
Derek
Old Sep 8, 2008 | 09:04 PM
jsteele90's Avatar
i drop mine down to around 12-14 psi
Old Sep 9, 2008 | 07:47 PM
01redws6ta's Avatar
Thanks for the input guys. I think I'll start out in the low 20's and see what happens...I'm hoping for no broken parts.
Old Sep 10, 2008 | 12:58 AM
Dave J's Avatar
I always found 14-16 good on et streets
Old Sep 10, 2008 | 09:39 PM
turningfast's Avatar
I use the same tire and use 18psi and can cut 1.6's with no hint of wheelspin, could go quicker but I am on the stock rear still. Also it is an auto V6 car, so it won't shock the tires nearly as hard as yours so you may need to go a little lower.
