Champion Drag wheels
Just like you don't want a cast crank or pistons, you don't want cast racing wheels.
Cast wheels are cheap to make and there is no way to control their grain structure. Also they are prone to defects, such as inclusions, voids, porosity, etc...
Forgings get "preferred orientation" of the grain structure, making them stronger and more durable.
Subscribed
Greg Weld's are like an old Datsun. Designed to be slow, built in a foreign country, but some "tuner" is bound and determined to make them fast.
Champions are fine as a 'Vette. Upper end looks and performance, relatively affordable price.
a 15x4 is 8.7
http://www.cwibeadlock.com/Dragracewheelweighttech.htm
Dont get me wrong, I'm considering these. Just wish they were lighter.
If they're 25 that's still o.k, heavier then I'd like but depending on the price compared to other comparable wheels that are out there I'll live with it.
Now if they were 35 lbs for the above size that would be way too much and would stop me from buying them.
Honestly I'm probably gonna end up going with a set of bogart welded r/t's and order them with double beadlocks on them right from bogart, this way they match my front rims. At this point it will be cheaper to get another set of bogart rears that match the fronts and just get them with the beadlocks on then it would be to buy another complete set of wheels.
I like the way mine look, it's just the beadlock and a 15x12 that I'm after.
