Champion Drag wheels
I have not seen too many double beadlock wheels on stock brakes anyway.
BTW, it has been asked before, but not answered, what are the benefit of going double beedlock over single? I know some of the guys I am building my car to compete with are running beedlocks to keep the tires (low 9's on 275 radials) in check. but not sure if they are running double or single locks...
Brake Clearance
I.D. of 15'' inner beadlock is 13.250. It is our recommendation that you CHECK CALIPER SIZE for clearance prior to purchasing a double beadlock for a 15" wheel. An easy way to do this is measure from the center of the axle to the outermost edge of the brake caliper. If this distance is less than 6.5", a double beadlock will clear your breaks without any problem.
Hope that helps you guys, wondering if they will fit stock brakes...
Ya I gotcha..I personally am running a single beadlock with dual rear strange calipers.
