Drag Racing Tech
pulls to left in wheel stand.........
Old Sep 27, 2008 | 09:38 AM
Ego Killer's Avatar
Default pulls to left in wheel stand.........
went to the track last night and tried out my new car I just built and it ran a 1.39 on the rear tires but it pulled to the left while coming down and had to let off. done the same thing 2 times. where do I start to fix this? I have adjustable LCA, PHB, body mount TA, and a Spoon drag bar. been racing for years but never had one this fast and had to worry about things like this. thanks in advance
Old Sep 27, 2008 | 09:54 AM
MADMAN's Avatar
LS1Tech Sponsor
Find someone with a sset of scales and call me. 225-673-3533
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 27, 2008 | 12:34 PM
tektrans's Avatar
Definately don't take my word over Madman's but I have the Spohn drag bar as well.
I would start taking pre-load off the passenger side so it doesn't push the car to the left so much. Start there and of course the obvious stuff-equal shock settings, tire pressure etc.
Old Sep 27, 2008 | 07:02 PM
LS1Z28-00's Avatar
thats a pretty good 60 man. this was on motor right? i heard you had some tranny probs tho. what did it end up running?
Old Sep 29, 2008 | 12:18 AM
358chevycamaro's Avatar
Madman will have that thing launching strait like it is on rails. All you need to do is find a set of corner scales so he can help you distribute your weight in all of the right places.
Old Sep 29, 2008 | 12:51 AM
TwoFast4Lv's Avatar
I set my car up to the letter as Madman told me to. I even had to call and have him tell the Chassis guy WTF we were doing.
Car comes up and goes dead strait EVERY time. MAN that is a good feeling
Old Sep 29, 2008 | 06:22 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Well one thing I can say, is no ***** to the walls runs. The sway bar needs adjusting as well as with playing with shocks and tires. Get it weighed as well, that is a great tool as well.
Ive been working with a car running 1.41 60 foots, and it always left straight but got put on the bumper, so travel limiters went in and now it raises the wheel not too much off the line and still leaves straight.
If you have a Sphon drag bar, is it the one that has tie rods welded to the frame or is it a better then stock replacement that uses the stock mounting points?
Old Sep 29, 2008 | 01:44 PM
Ego Killer's Avatar
it bolts in the stock location
Old Sep 29, 2008 | 01:53 PM
Internet Mechanic
Ah Ha.
Time to man up to a Drag Bar, that welds to the body.
Old Sep 29, 2008 | 02:01 PM
Ego Killer's Avatar
Ah Ha.
I had a wolfe dragbar on my old car it was really no better than this one. the car leave nice and level its just when it sits down about 60' out its pointed the wrong way.
Old Sep 29, 2008 | 02:30 PM
Internet Mechanic
Dont know your trans, or if you leave on the trans brake, if you do, you need that bar. PM JL-ws6, he can fill you in.
Old Sep 29, 2008 | 02:38 PM
Ego Killer's Avatar
I have a break but all this was on the footbrake.
Old Sep 29, 2008 | 03:10 PM
ATVracr's Avatar
Sounds like the rear is out of square.
We moved mine 1/8th inch and it went from almost hitting the christmas tree to dead strait.
Have someone heavy sit in the Ttop well to simulate the weight transfer then check the rear.... as the car plants the tire the rear can move because the PHB has one mount to the rear and one mount to the car.
Old Sep 29, 2008 | 08:29 PM
Hot Copper Z's Avatar
Mine was out by 3/16 on the right rear and pulled to the left bad,got it square and goes straight as an arrow now.
Old Sep 29, 2008 | 08:46 PM
kp's Avatar
kp
i have the spohn bar and cut 1.23-1.27 60 foots.
I have the same problem occasionally, first make sure your tires are the same diameter, 2nd make sure the rear is square, 1/4 turn of the LCA can make a huge difference on which way the car goes. Same with the sway bar preload and corner weights, so can a bind or bad shock but the rear being square is the first thing to make sure is right.
But a lot of mine is getting the car staged straight, if the car is pointed left or right on the starting line it has little choice to go which way its pointed when the front wheels are in the air. Especially when you start getting in the lower 1.3s.
Old Sep 29, 2008 | 08:54 PM
Brady's Avatar
LS1Tech Sponsor
X2, get a little help staging and make sure you're lined up straight. (free help)
Assuming you followed the Mad One's recommendation for scaling the car and it still goes left- get a four wheel alignment. (pretty cheap in the grand scheme of things.)
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Sep 29, 2008 | 09:22 PM
FastBlackTA's Avatar
I have done a 4 wheel alignment every time I have altered the geometry of my car (excluding pinion angle and tq arm settings). I have never had an issue with pulling left or right. It's cheap insurance considering the cost of wasting a track outing trying to get the car to leave somewhat straight.
Old Sep 30, 2008 | 07:26 AM
tektrans's Avatar
Ah Ha.
No need for it IMO. I cut consistant low 1.3's and even pulled a 1.29 with the spohn piece.
Guys going faster then me on it. kp for example.
Old Sep 30, 2008 | 07:51 AM
Internet Mechanic
Turbo cars hit different.
Honestly things like rear end geometry should have already been done.
Every car is diffent, even though its a 4th gen body, N/A your running a pretty sick time, but making sure the body doesnt bias to the right and no longer sits even on the suspension is key.
From my exp, power, weight (even on the 4 corners), trans, track condition, tire combo and suspension will influence this.
Until the car leaves straight, it should be launched and letting off well before the 330.
I will be getting that Sphon peice as well, my car just picked up a while and def bias to the right.
Old Sep 30, 2008 | 08:07 AM
Internet Mechanic
This is what mine did 2 weeks ago, 3720 race weight and making around 380-390 on a stick, BMR tq arm, LCA w/ relocation and pan hard rod, stock springs and shocks. I definitly will be bying shocks and sway bar next....
