Drag Racing Tech
ls2 question
Old Oct 4, 2008 | 05:31 PM
Taubr Unit's Avatar
Default ls2 question
Figure id ask here cause im sure you guys buy motors more often then others...
My buddy has a ls2 out of a TBSS with 30k on it. His dad works for a dealership and the truck needed new cats but they thought it was the motor so they put a new motor in it and he got this one. I have a chance to pick it up for $2k, good price? Fair enough i can pass it up and get one later down the road? AND since its out of a truck does that motor have anything different on it as opposed to a GTO. like the heads, fuel system or anything?
Old Oct 4, 2008 | 09:58 PM
JRracing's Avatar
The price sounds pretty fair for that kinda mileage. Does anything else come with it? ECM, wiring?
I'm not sure of any differences with one out of a car.
Old Oct 5, 2008 | 11:30 AM
InsaneAuto86's Avatar
Truck is iron block correct? I thought the accessories were mounted dif too..
Old Oct 5, 2008 | 11:48 AM
daniel6718's Avatar
accessories?
Old Oct 5, 2008 | 04:07 PM
9sec93's Avatar
all LS2's are aluminum block. the LQ4 and LQ9 are iron block
Old Oct 5, 2008 | 10:58 PM
WhiteLTone's Avatar
only difference between them i believe is the fan setup. TBSS ls2 uses fan/fan clutch assembly where gto ls2 uses electric fans. you could ditch the fan setup on the ls2 from the tbss and use yours from the lt1 i believe. i know a bunch of tbss guys have done the electric ls1/lt1 fan swap
