Drag Racing Tech
WHICH K MEMBER AND A ARMS ARE YOU USING?
Old Sep 11, 2003 | 09:43 AM
DopeFedZ's Avatar
Default WHICH K MEMBER AND A ARMS ARE YOU USING?
Sorry I know this is probably in the wrong section but they have asked in the other section and not to many responses. Which k member and a arm set up do you recommend. I heard from badz that he like the PA stuff and then another member says his has been nothing but trouble with PA fitting right and having to mod it forever to fit right. Does anyone know anything about AJE racing stuff i think it is Anthony Jones?? What about BMR? Sorry for all the questions hope someone can help.
Old Sep 11, 2003 | 09:50 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Default Re: WHICH K MEMBER AND A ARMS ARE YOU USING?
I am using the PA K-Member and BMR A-Arms. Both work very well. No modding to make it fit.
Old Sep 11, 2003 | 10:15 AM
Big Rick's Avatar
PA k and arms.
Old Sep 11, 2003 | 10:17 AM
DopeFedZ's Avatar
any fitment issues how much weight savings? thanks for your reply
Old Sep 11, 2003 | 02:53 PM
DopeFedZ's Avatar
ttt
Old Sep 11, 2003 | 03:45 PM
Big Rick's Avatar
No fitment issues whatsoever for my setup.
Old Sep 11, 2003 | 05:17 PM
andy98Z's Avatar
Do u guys have new motor mounts as well?
Old Sep 11, 2003 | 07:13 PM
BADZ's Avatar
Moderator
Yes, PA K-member, PA a-arms and yes, solid motor mounts and no fitment issues what so ever....Perfectly satisfied..
Old Sep 11, 2003 | 09:07 PM
Gofast's Avatar
I have the PA chromoly K-member but I use the Strange Engineering complete strut shock package which elimanates the top a-arm this is designed for stock strut towers. see Strang Engineering. This setup is the lightest you can have next to going with a ultra drag race strut. I have had the PA chromoly arms with QA1 adjustable shock setup and it was very nice and the car had no alignement problems what so ever. Here is a pic of how the front tire ride height setup looked like with the PA arms and K-member without the engine in the car all of which can be adjusted. Very good quality!
www.gofastzone.com/members/The%20KING/016_25a.jpg
Kent1's Avatar
BMR Kmember and Upper and Lower A arms with no fitment issues--just a few poping sounds.
Old Sep 11, 2003 | 10:25 PM
Colonel's Avatar
I use PA with no problems.
Old Sep 11, 2003 | 11:00 PM
mighty mex's Avatar
PA K-member for now
still got the stock A-arms but im pretty interested in the BMR A-arms.
as far as the K-member goes, it bolted in with no problems whatsoever also got solid motor mounts
Old Sep 12, 2003 | 12:57 AM
BIGBOS's Avatar
Do any of you guys drive around daily with the K-member, A-arms? How is it?
I'm thinking about doing it to my car, but I drive a lot...
Old Sep 12, 2003 | 09:00 AM
WILWAXU's Avatar
For a daily driver. Go for a BMR setup. I've been able to compare the PA, AJER and BMR in the past 2 years. The BMR is whats going on my car (heavy street use).
The tabs for the control arm mounts on the PA K member are built very light and would concern me on a daily driver.
The AJER K member is well built, actual pockets for control arm mounts. Their control arms are a little on the light side.
The BMR K member and control arms are built "beefy" and appear to be the best for continued street use IMO.
Old Sep 12, 2003 | 10:33 AM
Colonel's Avatar
FWIW, I used to daily drive the PA K-member before the car turned into a trailor queen. Drove it for about a year or so like that.
Old Sep 12, 2003 | 12:04 PM
WILWAXU's Avatar
BTW: AJER = Anthony Jones Enginerring
Old Sep 12, 2003 | 05:49 PM
MIGHTYMOUSE's Avatar
allignment post k member and or a-arm install.. is this mandatory on lets say a full bmr set-up.. probably a stupid question.. i just don't want to let a sears 'technician' wrench on my ride.
Old Sep 12, 2003 | 06:47 PM
DERTY's Avatar
The Bull
ARE K-Member and lower A Arms. Fitment was great and holds up extremely well!
Old Sep 13, 2003 | 01:56 AM
Big Rick's Avatar
Yes an Alignment is definetly Mandatory since you're changing all the points that affect/adjust the alignment
Old Sep 13, 2003 | 12:02 PM
bspz28's Avatar
I have the BMR K-Frame and lower A-Arms
