Drag Racing Tech
Painting weld in roll bars
Old Sep 11, 2003 | 01:55 PM
Magnus's Avatar
LS1TECH Sponsor
Default Painting weld in roll bars
You need to get them painted after they are welded in... How much and where do you guys get them paitned?
Do you paint them your selves? I would love to do that.
Old Sep 11, 2003 | 02:02 PM
MilDot's Avatar
Default Re: Painting weld in roll bars
I just covered everything in newspaper, taped it off fairly well and busted out the spray paint. A couple coats of black and a coat of clear. I will be getting it covered later on so I just wanted something to prevent rusting.
Old Sep 11, 2003 | 03:08 PM
Camaroholic's Avatar
I started taping newspaper down (err, and up also) last night...
Lots of newspaper. It'll be another week before I have enough, I think. The Waco Trib is pretty thin.
-Andrew
Old Sep 11, 2003 | 03:20 PM
98TAauto's Avatar
old blankets work.. just dont let your mom or wife know you painted them up LMAO
i plan on doing mine myself.. CAT3 did his own and a few others and they look great. He emailed me some pointers(thanks man).
you could paint the pain parts before you install them. Just leave 4-6 inches from the edges undone, then touch those up after its in the car.
Old Sep 11, 2003 | 07:34 PM
2001 Pewter WS6's Avatar
Restricted User
I had my whole cage painted then ground the paint off just where the welds were going then all I had to do was a touch up the welds. Came out great...
Old Sep 11, 2003 | 07:47 PM
DaveSchott's Avatar
newspapers? too much work. Go to home depot/ lowes and get a reasonably thick plastic drop cloth, that way you can cover the entire car and slit the drop cloth to fit over the bar then tape it up.
Old Sep 11, 2003 | 07:48 PM
Magnus's Avatar
LS1TECH Sponsor
spray paint or brush paint?
Old Sep 11, 2003 | 10:51 PM
CAT3's Avatar
Restricted User
Magnus, Spray...Krylon works great, quick dry time and easy cover, and touch up. Plus you cant beat the color match if you have tan interior
I knew I should have saved the write up I did for 98TAuto.. If you still have it could you forward it too Magnus? Thanks.
Pics in link in sig.
Old Sep 12, 2003 | 06:47 AM
Fireball's Avatar
I painted mine in a booth outside the car (having short down bars and swingouts allowed for this). taped off the bottom 3/4" of each point to allow it to be welded to the car.
http://home.comcast.net/~krzewinskibe/front.jpg
After the paint cured for a day or so it was placed in the car and welded to the mounting plates.
http://mywebpages.comcast.net/krzewi...car/right2.jpg
http://mywebpages.comcast.net/krzewi...incar/weld.jpg
http://mywebpages.comcast.net/krzewi...oorbaropen.jpg
http://mywebpages.comcast.net/krzewi...ncar/back2.jpg
http://mywebpages.comcast.net/krzewi.../incar/top.jpg
Old Sep 12, 2003 | 11:03 AM
Magnus's Avatar
LS1TECH Sponsor
ok Thanks guys.. I'll give it a go with a high gloss black spray paint, 3 light coats.. and then a coat of clear.
Old Sep 12, 2003 | 11:10 AM
Fast SS on TNT's Avatar
House Of Krylon....it aint fancy, but it should save my life if I put the bitch on the roof!
Have fun
Old Sep 12, 2003 | 02:26 PM
2001-WS6's Avatar
Here's the plan. Head to Home Depot and get a few big packs of the thin mil plastic covering for painting. Lay one so it covers the outside of the car. Run another so it goes from the outsid of the trunk through to the inside of the car along the roof and over the bar then down the back of the front seats. Lay another sheet from the rear seats to the back of the trunk. Cover the insides and the outside of the doors and the front seats.
Hi your local Home/Auto paint store. Tell them you are paint a roll cage in the car with cans. They will recomend a cleaner and primer appropriate for Milled or Chrom moly steel. They will set you up with a self etching primer, 2 cans of 15-16 ozs in black or grey. Pick your favorite color mid sheen or semi gloss enamal and get 4-5 cans 15-16 ozs to put two good full coats on. This will leave you with some for touch up work for the first year.
Keep a box top handy for blocking areas that get exposed as the plastic shifts while you're climbing around in there paintings. Where the latex gloves with a new set per can because you're going to tear them up moving around in there. Get all the other cars out of the garage for the day because this stuff hangs in the air. Allow for two days to get it done since most self etching primers work best if painted on within the first 18-24 hours.
Plastic, tape, sand, clean, prime, paint, paint and touch up, and then peel the plastic and enjoy. Don't panic if you sneeze black for a few days.
Rick
Old Sep 12, 2003 | 02:39 PM
Magnus's Avatar
LS1TECH Sponsor
Damn rick that sounds compicated!!! Thanks for the writeup though.
Old Sep 12, 2003 | 03:01 PM
Don't forget the SFI 45.1 padding around your head. Don't use pipe insulation.
Click here for an article discussing padding
Have fun.
Andrew
