Battery relocation kit?
Cheers
Al
From what I saw online it looks like this is pretty much a do it yourself job. No one offers every part you need in one kit.
If you want a 100% leakproof and 0 fumes battery look towards what the audio guys use. Kinetik I think they are called. You can put them upside down, literally.
I will call asap,might be a week or so up to my eyes in work at present due to coming to US for 2 weeks vacation in Vegas for racing and SEMA, Will you be at SEMA?
Having looked on your site there are a few other items I might need.
i don't believe i'll be at the SEMA show, but you never know, things might change. Madman will probly be there.
I looked at the multiple ground points my Y2K Camaro has and decided to ground in front when I moved the battery to the back. My plan was to conceptually just extend the stock wires to the back to avoid any problems. I bought a kit and extra cable from Summit, getting the largest cable they had. The car would not start unless I had a charger on it. The computer would not work right when the voltage got below about (IIRC) 10.7V, which it readily did with the voltage drop in both directions. I grounded the battery to the body in the rear and now it usually starts. As long as the battery is fresh and topped off it is ok. So, this winter I will do some rewiring. I will either parallel the old ground lead with the hot lead or buy welding cable to get cable with more capacity.
I never have starting problems and my car has higher voltage than ever after my battery swap.
My ground is maybe 4 inches top. Plus, I think the stock connectors are insufficient when you get to those lengths. They are paper thin stamped and coated. No good.
