bad wheel hop problems
I run 15 psi in tires and have adjustable torque arm...
I still have stock bolts in My lca's could that be the problem that I need 1/2 inch bolts...
Also, check the t/a clearance at/near the seat belt anchor plate. Some 9"/lowered cars can have interference at that point, and totally screw up the chassis setup. Also, check the brkt and the bolts @ the 3rd member.
Did you use the poly bushing that came w/ the t/a?
Last: Do you have an adjustable panhard bar? Was the rearend centered, after you lowered it? That will affect t/a clearance.
3rd member is good and I got poly bushings
I run car last night on street just to see how it done with shocks adjusted middle ways and bout 18 to 20 psi of air still hops
