depressing #'s dyno and track....
Old Dec 19, 2008 | 01:28 PM
  #41
slow trap's Avatar
Originally Posted by svsgt1
This may help (you feel better anyway) as I have a similar setup and made only 405rwhp with a manual. I have 61cc Patriot LS6 heads and 11.5:1 comp ratio, MS4, Vic Jr intake, headers, internals, stock rockers and Caddy racing lifters. Its not the first time I've heard of this hp with this cam and setup.
wow. an ms4 with ported heads through an m6 should be 450 + i had a 228 cam that did 436 with 57 cc heads. something is wrong with both of you guy's setups imo. good luck finding the lost power.
Old Dec 19, 2008 | 02:19 PM
  #42
greatskiiiier's Avatar
+1 for valve float
Old Dec 20, 2008 | 05:52 PM
  #43
MattysTA's Avatar
whos doing the tuning and with what software? and how is the tuning being done? i also do street tuning with efilive and i can do it by wideband and narrowband with the ltft's.. what are you using? what are your o2's reading at WOT?
Old Dec 20, 2008 | 05:57 PM
  #44
bww3588's Avatar
he used EFIlive and we did it on the street.
Old Dec 20, 2008 | 06:17 PM
  #45
MattysTA's Avatar
do you have the latest data log and tune file so i can take a look at it?
Old Dec 20, 2008 | 06:37 PM
  #46
bww3588's Avatar
no, i gave up on this project a while ago. im pulling the motor, going to change the cam back to stock and put the stock valvetrain in it, new bearings and have it rebalanced and sell it. im going with a TSP 408 and a healthy shot of the sauce.
Old Jan 25, 2009 | 07:24 PM
  #47
svsgt1's Avatar
I was using a LINK G2 Plus ecu. Odd ecu for this motor. I'm also running through a 6 speed Audi transaxle but I don't think that will hide 60rwhp. Anyway, the car runs fine and makes tons of power since it is only 2100lbs but I woudl still like to find the extra hp. Not sure if it is the intake of not.
Old Jan 26, 2009 | 04:26 AM
  #48
bigfatls6's Avatar
You should have had it retuned. I had my old camaro with ported 853s and a torquere v.3 street tuned by one place and then I had it dyno tuned some where else. The first run on the dyno it only made 353 and was way rich and not enough timming. After the tune was done it made 403 and 379 tq in an a4 and would run 11.40s
Old Jan 26, 2009 | 03:31 PM
  #49
bad6as's Avatar
take off the sprial flows!!!! i lost over 30 hp with my cut out shut
Old Jan 26, 2009 | 03:48 PM
  #50
smok'nZ's Avatar
MASS seller approved
408 is a much better choice by far anyways
Old Jan 26, 2009 | 04:11 PM
  #51
LSGunZ28's Avatar
That setup should be at least 50+RWHP more. AT LEAST, and that is with a stock UDP, your MOSER 9", Steel FW and those headers and the LS6 manifold, etc..
