Disappointing dyno, unrealistic goals?
98 ls1
ls1 intake (yeah...I know)
2000 heads
comp xe 230/224 111+3 cam
ported throttle body
stock maf
cone filter after 90 degree rubber intake tube
doug's headers
2 1/4" exhaust with dual cutouts 1.5-2 ft behind collectors
pac springs
7.4 pushrods
ported oil pump
tranny is stock with a transgo kit (not the shift kit, just a corrector kit)
12 bolt posi 3.42 gears
steel driveshaft
tuning by wait4me
the only other thing I can think of is that the transmission was in 3rd instead of drive, but that's what I was told to do
I guess maybe my hopes were just too high but I was hoping to see at least 350hp on a dynojet. Maybe I'm just getting hit with enough pissy little things to add up to big loss. My biggest concern is the way power drops so quick at 5600rpm. Even the other guys there with stock ls1 intakes didn't seem to have that problem.
Open to ideas though, and a ls6 intake is on top of my list. Guess I might be losing more in the tune than I expected...but hell for $60 I can't complain.
In the second pull (red lines) they drop off hard because the tailshaft housing busted and there was a lot of smoke
i got bit by the big goal bug too. i dynoed REALLY low for what i thought it would be before H/C, and not exactly in line after the tune and install, but i always forget how much the A4's really take. the numbers will fool you though...
http://www.tpis.com/index.php?module=2_17_06
the advance in the cam is the same 3 degrees thunder racing grinds into theirs, its installed straight up, just ground in advance
keep the ideas coming though guys, appreciated!
a true dyno/street tune might wake it right up, that's kinda why I was asking...I expected to be down on some power from the tune but this was a little lower than I expected
