PRC 215's , Tsunami ,RPM-Ported FAST 90/90-base results...
Old 02-09-2009, 03:50 AM
  #61
Spectre86's Avatar
any new numbers with the new headers?
so as far as the tsunami cam goes, it looks like its pretty close to your ms4. Interested if you have any comparison
tsunami-235/240, .654"/.609" 111LSA
MS4- 239/242, .649"/.609" 111LSA
Is there any difference is the lobes that you chose from comp with these two cams?
Are these PRC 215s CNC'd like stock ones or an entire aftermarket casting?
btw, any videos yet?
Old 02-09-2009, 07:57 AM
  #62
TVWilkes's Avatar
The PRC 215 heads are an entirely new aftermarket casting.
Old 02-25-2009, 04:05 PM
  #63
Spectre86's Avatar
Originally Posted by 1badzo
Any new numbers with the new headers?
x2. 1 7/8 headers! still waiting. lol
Old 02-26-2009, 02:39 PM
  #64
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Anyone is welcome to come down & checkout our cylinder heads at this facility. I'd be more than happy to show them to you next to anyone's cylinder head in the country. This is a complete new ground up casting with tons of sweet features.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-26-2009, 08:54 PM
  #65
Spectre86's Avatar
fee free to send me a trial set
Old 03-02-2009, 04:13 PM
  #66
candlelit's Avatar
since the specs are so very close to a MS4, is that going to make the daily driving not very much fun? I mean, you guys that have the Tsunami cam, what do you think about driving it around?
Old 03-02-2009, 10:49 PM
  #67
golfinz's Avatar
The ms4 has 3 more degrees of OL than the tsunami (assuming the above duration and lsa are correct) so I would assume that they drive pretty close to the same...
Old 03-02-2009, 11:15 PM
  #68
pewter2165's Avatar
Yeah... she bucks down low taking some time to get use to.
Old 03-03-2009, 07:58 AM
  #69
COOKIE MONSTER's Avatar
Again jason, NIce numbers...
Old 03-04-2009, 07:55 AM
  #70
ryan@rpm's Avatar
For all that have asked about the new #'s with the 1 7/8" headers. I did try with new injectors and headers but I was getting some oil in the combustion chambers. I am replaceing the pcv valve and adding catching can to hopefully solve this problem... I was able to get 483 rwhp and 428 rwtq... but this was with hardly any timing in the motor due to knock ... So maybe this weekend I can get some good #'s out of my car !
Jason
Old 03-04-2009, 11:05 AM
  #71
want297z's Avatar
Good luck chasing the oil, even with a catch can I still get carry over sometimes. I think I need to rerun it as the original owner did it and I am not 100% sure it is done correctly.
Very nice numbers none the less. Man I need some different heads.
Old 03-04-2009, 01:40 PM
  #72
180ls1's Avatar
very nice numbers but if i were you i would get a flowmaster 4" merge and a 4" cutout then have it go back to 3" for your catback, since the tsp one is not the best and at that power level you should want more flow.
Old 03-05-2009, 07:44 PM
  #73
99blancoSS's Avatar
very nice results, congrats guys
Old 03-24-2009, 02:29 PM
  #74
SOMbitch's Avatar
Hey JK,
Final #'ers????????
Old 03-26-2009, 07:59 PM
  #75
BlackLS199's Avatar
video yet??
Old 03-26-2009, 08:36 PM
  #76
2003cobraH/C's Avatar
ahhhh quit knocking around... Get rid of that oil and send us some updates. Good to see some high quality cnc new aftermarket cast heads rolling around now. A few hundo cheaper than trick flows, and godly more powerfull than the ported ls6 heads.
Old 03-31-2009, 06:09 PM
  #77
BlackLS199's Avatar
Is he ever going to post back with some new info?
Old 03-31-2009, 11:56 PM
  #78
Frost's Avatar
I know this thread is a bit old but...
The OP said he ran 42lbers static. I can make 570rwhp or so with those and a blower running at a fat 11.2ish:1 with a walbro pump pushing them. They should be good for more on an N/A setup. Check your fuel pressure, I'll bet it's falling. You didn't mention pump, but if it's stock, it's the culprit.
Old 04-01-2009, 01:48 PM
  #79
ryan@rpm's Avatar
No what I mean't in the OP was the entire fuel system is stock on the car.. I did install some 42#'s just have not had a chance to get it back on the dyno since they were installed !
Old 04-08-2009, 04:51 PM
  #80
Spectre86's Avatar
updates?
Quick Reply: PRC 215's , Tsunami ,RPM-Ported FAST 90/90-base results...
