PRC 215's , Tsunami ,RPM-Ported FAST 90/90-base results...
#81
Are you saying the SI6 cam is the same cam (same lobes, everything) with a different name, or that it is just the same size at .50 lift?
#82
If you knew me on a more personal level, or vice versa, you would tell it was a bit of sarcasm. Theirs an area of duration and overlap that works well for these combinations; it just happens to be within those duration numbers. So I don't see it as a lobe sheet wheel of fortune. We do alot of work on the dynojet, you guys do more on the engine dyno. Its no surprise we ended up at a similar vantage point.
Good work on your cylinder heads
apologies if you took my comments out of context
Fraser
Fraser
guess i should have kept reading the thread. Ignore the post above.
#89
Sorry guys I just noticed yall brought this back up. I was able to squeeze 10 more out of the combo, the only changes I made were TSP 1 7/8" Longtubes and 37# injectors. Also I have about 25K miles on this combo (daily driver) and have had ZERO problems so far ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i171.photobucket.com/albums/u306/rpm1_photos/jkbest.jpg)
#94
#95
Somebody get this car to 500RWHP! I along with everyone on here want to see if an electric water pump and a pulley will do the trick.
If not well then there are not to many other options on a stock bottom end LS1.
Possible recipe for a hydrolic roller 500RWHP stock bottom end LS1/LS6:
-Ram air mod
-Some filter that barely holds anything back
-104mm FastToys airlid
-TSP 100mm MAF
-FAST 102mm throttle body
-Ported FAST 102mm manifold
-PRC 227cc heads with 57cc combustion chambers to get that compression up to 11.4:1
-thinner 0.045" MLS gaskets to get that compression up to 11.5:1
-TSUNAMI camshaft or some other all top end cam
-KOOKS headers with 2" primaries and 4" out
-No cats, no mufflers, jump dump it after headers
-No AC
-No power steering
-Electric water pump
-Underdrive pulley
-7000RPM redline
-93 octane
-Some anything but conservative extreme pro tune
(With stock clutch, T-56 tranny , aluminum driveshaft, 10-bolt rear-end, 3.42 gears, rims and tires)
and voilą...500RWHP and maybe, just maybe, a little more
lol
-Ram air mod
-TSP 100mm MAF
-No AC
-No power steering
-Underdrive pulley
-7000RPM redline
-93 octane
lol
Last edited by 35thAnniversaryPhil; 10-20-2010 at 10:08 AM. Reason: just got a crazy idea
#96
By this time, I hope an electric water pump and underdrive pulley were installed
I'm curious to see if new numbers came along with the updates
