TR224 Dyno Results Inside!!!
Having just installed my TR224 112 @ YT 1.7 rockers the SS needed a new tune so off to Rapid Motorsports. Weather in eastern PA was beautiful today so all in all a great day.
First dyno pull was 350 rwhp @ ? torque on the LS6 cam tune.
After Mikey's tuning it raised to 366 rwhp and 352 rwtq. That is the highest Mikey could get through full exhaust. Mikey and I were perplexed as the my old LS6 cam beat the hell outta my TR224. Well here's the kicker we then opended the cutout and tried again............. 399 rwhp @ 386 rwtq Stock 10 bolt w 3.42's no dyno tricks car was dynoed as it is driven on the street. So if we do the math that is a 33 rwhp @ 34 rwtq gain! That means the CC baffle in my I pipe is one hell of a restriction !!!! I would have liked to have dynoed thru full exhuast but with the baffle in the trash can where it belongs.
I don't have a scanner handy so here is a quick breakdown of the numbers. I will be posting the graph ASAP using a friend's scanner.
1st numbers are TR224 thru exhaust with baffle in I pipe
2nd numbers TR224 w open cutout
3rd numbers are old LS6 cam thru full exhaust minus CC baffle
HP
2.5K 160 160 160
3.0K 185 194 180
3.5K 227 235 220
4.0K 260 280 265
4.5K 300 325 308
5.0K 330 370 345
5.5K 355 390 371
6.0K 364 399 376
6.5K 360 390 370
TQ
2.5K 297 302 300
3.0K 328 340 318
3.5K 347 360 325
4.0K 350 375 346
4.5K 350 379 357
5.0K 348 386 361
5.5K 340 370 350
6.0K 320 350 325
6.5K 280 315 300
Well there you have it! The numbers are as close as I can tell reading off a dyno sheet but you will get the big picture. I am damn well pleased at how my car performed but I will definately be ripping out the Car Chemistry Baffle!!!!!!!!!
JBsC5... I am running Comp918's blue stripe, Comp titanium retainers and TR chromoly pushrods along with the Yella Terra Roller rockers up top.
Mike K... Allready got the QTEC and I love it so far!
catalytic converter? if so, you use only one cat?
what is "CC baffle in I pipe" from your sig? doesn't the normal jet-hot header and Y pipe come with two cats that slip on right after the header collecter? man, i'm lost.
nice cam only numbers by the way!!
on the car on the dyno just to squeeze 1 more hp out for that magical 400.
