Dyno Results: MS3, 5.3L Heads, Fast 92
Old 04-29-2009, 11:11 AM
  #81
T.A.WS6
Guest
Posts: n/a
nice numbers
Old 01-16-2011, 10:46 PM
  #82
lswon240's Avatar
very nice just i'm hoping to put down around 425 if my car ever runs
Old 01-16-2011, 11:06 PM
  #83
HOTROD98Z's Avatar
A little bit of an old thread, but did you ever get any track numbers?
Old 02-07-2011, 01:14 PM
  #84
GT_EATR's Avatar
Yea.. Gotta see some track times with numbers like that..
Old 02-07-2011, 10:30 PM
  #85
wantsum410's Avatar
I am running this same setup in my '72 SS Camaro [Fast 92/92 is not ported]
8.5 10 blt with Detroit lkr,4.56's ,m6.
I leave on the limiter at 6900 rpm & side step the clutch [stock rod bolts for 5yrs,20k miles]shift at 6600 rpm . Well my best times are 11.43 at 119 1/4 mi.7.30 in the 1/8...
These were on ET streets & consistancy was not to be had .. I now am running ET drags .Tonight I pulled the MS3 & installed a Pat G custom cam with EPS lobes to get more trq dwn low as the MS3 is lacking & stick cars NEED !Oh ye there is a set of Katech Rod bolts going in also.
Anyway I put 20k on this cam, 3 PWR tours ,4 sets of tires ,3 RAM hd's....#!*^#!!! Monster stg 3 now.It was alot of fun & with a Geoff Skinner tune I could cruise at idle [950rpm] without bucking or surging 95% of the time !
Car put 430 rwh /390rwtq with a LS6 intake & Thunder Racing P&P TB .It ran 11.53 to 11.58 's with this setup.Car is 3400lbs without me [190lbs] in it .
If you want to see some video of it pm me for the link .
Old 02-08-2011, 02:12 AM
  #86
lilmiller74's Avatar
Nice numbers, I have the same heads/cam but with an ls6 intake, p/p stock tb, and 1 3/4 pacesetter lts and I only made 440/398.
Old 02-22-2011, 12:51 AM
  #87
SsSteven's Avatar
Me too, same setup w/o the fast 92/92.
Best time was 12.7 @117, I need 315s in 17s.
Old 02-22-2011, 01:18 AM
  #88
My best is 12.02@118 on stock gear. I have 17x10.5 with 315 nitto drs
Quick Reply: Dyno Results: MS3, 5.3L Heads, Fast 92
