stock bottom end f1-c
Old Feb 19, 2009 | 05:48 PM
charged 434's Avatar
Default stock bottom end f1-c
I am finishing putting together a stock bottom end ls1 with victor junior intake 90 mm tb, 224/228 114 cam. manley springs, kooks headers f1-c procharger, turbo 400. i am probally forgetting some thing. what kind of power do you think it will make and how long will it last, oh yeah meth inj. going to run 93 octane
Old Feb 19, 2009 | 05:49 PM
oh going to run 10 lbs
Old Feb 19, 2009 | 05:53 PM
FMX05's Avatar
About 10 minutes on 10 psi.
Old Feb 19, 2009 | 06:03 PM
Slowhawk's Avatar
LS1Tech Sponsor
Must be a 5" pulley to make just 10lbs on that motor. Either way it could last 5 minutes or 5 years.Should make 650-700 flywheel hp. Too dificult to figure out a RW hp due to the T400.
Old Feb 19, 2009 | 06:13 PM
BigRich954RR's Avatar
stock bottom ls2 here at 15 psi was at 11psi for 6 month 15 psi for 4 months F1C here
Old Feb 19, 2009 | 06:17 PM
it is a 5 inch pulley , i know it will not last long, i am building a 434 lsx block engine next year, for now i want to see what it will do , for a short while haha
Old Feb 19, 2009 | 07:55 PM
TurboAv's Avatar
I hope it's not your daily. If it is your probably going to blow it when you least expect it and can't afford it. If it's not your daily it will probably live just fine until you get the new motor built. Gotta love Murphy...
Edit: What's the difference and advantage of going F-1C over the F-1A? I was thinking of doing the F-1A on my car, but I'm curious about the F-1C.
Old Feb 20, 2009 | 09:26 PM
z28boy's Avatar
I am sure it will be fun while it last.
Old Feb 24, 2009 | 08:31 AM
chris23120's Avatar
id run meth
Old Feb 24, 2009 | 08:32 AM
chris23120's Avatar
ls1's rule
chris23120's Avatar
should make nice numbers
Old Feb 24, 2009 | 12:42 PM
let us know what numbers it puts down
Old Feb 24, 2009 | 01:16 PM
SELLSZ06's Avatar
F1a here with a 5in pulley AFR 225s ls6 cam, I am making only a lil over 6lbs, but Im forged ls2 365". just to give you a reference point
Old Feb 24, 2009 | 07:41 PM
V10GTS's Avatar
I think it will make it a while as long as the af is good.
Old Feb 24, 2009 | 08:43 PM
flyinmedic's Avatar
I have a D1SC at 9psi and put down 653rwhp/546rwtq and its a stock block and heads. Stock internals except the cam. I drive it 4000 miles a month and it has 53000 miles on it. No probs yet. It's getting meth this summer and should be around 720rwhp
Old Feb 24, 2009 | 08:52 PM
Slowhawk's Avatar
LS1Tech Sponsor
Your #'s are pretty common for a stock/cammed motor and they last a long time IF they are not beat to death.
But the person posting is running a T400 which will put alot more stress on the motor/blower combo which would lead to failure alot quicker.I highly doubt the 5" pulley will strain the motor,so with a good tune it will last a real long time.The downfall is the blower will be way under it's efficiency for now.
Old Feb 24, 2009 | 09:35 PM
ItsNotStock's Avatar
Who agreed to tune that big of a head unit on a stock bottom end? Lol. The meth is going to buy you time but I don't give it six months. I hope I'm proven wrong but I remember seeing a Corvette owner in Europe who ran an F1-A on a stock motor with comparable octane (XX Ron) blow his engine up. He even ran D1SC pulley's I believe to run lower boost.
I would just drive the engine without the kit installed until you have a built motor for it.
Old Feb 24, 2009 | 09:39 PM
ThaT SLOW GUY's Avatar
Just spray the **** out of it and call in the day!!
Old Feb 25, 2009 | 10:20 AM
I run a 4.75 blower pullley and 8 inch crank. With a f1c my stock ls2 bottom end is holding up fine but I do. Run it on the a/f rich side . With a lot of meth injection. Being beating the crap out of it for over a year now. Don't worry put the kit on and save for a rebuild cause it will need it. But not right away if the engine is good.
Old Feb 26, 2009 | 07:44 PM
I do have a meth kit going on it. ordered 5" pulley today. still waiting on a few parts. going to mount the supercharger this weekend hopefully. i will try to get some pict of the car this weekend. it looks pretty good. but that does not help the motor last any longer lol. oh well it should last a little while with a safe tune.
