LS6 Top End Numbers
Old Feb 20, 2009 | 10:02 PM
kdavis's Avatar
Default LS6 Top End Numbers
I have the ls6 set up on my trans am with a 4c stall converter(2.4 str), 1 3/4 headers, lid, cutout, and usual bolt ons. I tuned the car at henderson performance technologies yesterday and it made 353.96 hp and 342ft lbs but it looks like it flat lined at 5400 rpm. it might just be where the cam stopped making power. the car has the stock 99 ls1 injectors and stock fuel pump with 154000 miles on it.
Old Feb 20, 2009 | 11:18 PM
98camaroLS1M6's Avatar
Looks good thru the auto, power peaks at 5400 but holds on til 6200+, seems healthy.
Old Feb 22, 2009 | 04:34 PM
stumprrp's Avatar
looks great man, 400+ with a cam.
Old Feb 22, 2009 | 04:39 PM
kidcamaro98's Avatar
here buddy...
I have a 01 LS6 long block in my SS also, I have just intake, headers, off road Y pipe, LM1 exhaust into the factory CME tips, ported TB and stage 2 RAM HD power grip clutch....No dyno tune. I put down 351rwhp, 355rwtq on a low reading dyna pack (reads 10% lower then the local dyno dynamics)...heres my graph...
at the time of this dyno, the motor had 8k on it...now I have 10k. These are SAE corrected.
Old Feb 22, 2009 | 04:41 PM
MattIROC's Avatar
Did Corey tune it, or one of his employees? Back in 05 I dealt personally with Corey, he did a great job tuning my 6spd. Nice numbers with a stock cam.
Old Feb 23, 2009 | 05:56 AM
HioSSilver's Avatar
my 02 ls6 crate results in the sig
Old Feb 23, 2009 | 07:44 AM
LS1-450's Avatar
Agree w/ the others. Good numbers, no worries.....154K & going strong.
Old Feb 23, 2009 | 10:26 AM
z28voodoo's Avatar
now do you all swap from a corvette ls6 engine? like the Z06 or what?
Old Feb 23, 2009 | 11:41 AM
kdavis's Avatar
i just swaped in the ls6 heads, cam and intake. i wanted to keep the good gas mileage and have a sleeper car. The motor only has 1500 miles on it since the swap. Cory tuned the car, not complaining by any means. The car went 11.9 with 325 hp before the tune with a 14.0 a/f. i am going to put 28# injectors in. I was just curious because it quit climing.
Old Feb 23, 2009 | 11:46 AM
MikeG's Avatar
I think something is holding you back. The curve just plateaus way too suddenly. LS6s are supposed to peak higher than LS1s. My bolt on LS1 w/ a PT4000 makes the same power and 24 rwtq more. Something is amiss.
Old Feb 23, 2009 | 12:04 PM
kdavis's Avatar
im thinkin its the fuel system. the exhaust is 1 3/4 headers and 3in to the axel with a cutout.
Old Feb 23, 2009 | 02:17 PM
Mine was a brand new 01 Factory LS6 long block I got from a local GM dealer.
Old Feb 24, 2009 | 08:27 AM
chris23120's Avatar
nice numbers
Old Feb 24, 2009 | 07:43 PM
V10GTS's Avatar
is this on a mustang dyno or a dynojet?
Old Feb 24, 2009 | 07:44 PM
V10GTS's Avatar
great numbers considering the milage
Old Feb 25, 2009 | 02:03 AM
kdavis's Avatar
the motor only has 1500 miles on it. the car was dynoed on a dyno jet
Old Feb 25, 2009 | 02:20 AM
jetlag's Avatar
Yeah, I'm going to go with the weak fuel system idea.
Old Mar 11, 2009 | 03:01 PM
1Bad00SS's Avatar
Dyno graph is definately off.. my power peaked around 6 and held to 6500 before it dropped off with the ls6 setup, I do have a fast 78 manifold though. Your a/f stays at 13:1 so it's not the fuel.. maybe some kind of intake restriction like the maf, air filter, or throttle body?
Old Mar 12, 2009 | 12:54 AM
kdavis's Avatar
so should i port the tb now? i have a K&N drop in filter, stock tb(unported), p&p descreened mass air. i am goin to take the car to tune it for the nitrous in a few weeks.
Old Mar 16, 2009 | 07:35 PM
user 70810891082's Avatar
Something is wrong. That combo should peak in the 6200-6300 range and then taper. I am guessing you are 15rwhp short or so.
