Base Line Pull 09 G8
Old Feb 25, 2009 | 05:06 PM
Charley@FMS's Avatar
Default Base Line Pull 09 G8
Third Gear Pull 313hp - 337tq.
Old Feb 25, 2009 | 06:04 PM
allngn_c5's Avatar
Very small pics. Can't see them too well. 313/336 to the wheels ?? Sounds good for a baseline 100% factory stock G8.
What are your plans for this car ??
Old Feb 25, 2009 | 07:32 PM
ScreaminRedZ's Avatar
registered user
Damn, that sounds like a strong one! Great color choice, too.
Old Feb 25, 2009 | 09:55 PM
My wife doesn't know what she wants to do yet. Still deciding......
Old Feb 25, 2009 | 09:59 PM
98camaroLS1M6's Avatar
Strong numbers!
Old Feb 25, 2009 | 10:34 PM
I will re-dyno in fourth to see what I end up with. I did'nt know every one else was useing 4th due to the ratio. This was done for me at work, lets see where that puts the numbers at.
Old Feb 26, 2009 | 11:29 AM
PewterScreaminMach's Avatar
Let us know the 4th gear numbers. I know there is no 1:1 in the G8 A6 so I'm assuming, according to what you said, that 4th is closer to 1:1 than 3rd, so I'm curious to see how much of a difference it makes.
You chose the best color available for the G8s, by the way. I tried to convince my brother to buy the blue one when he was shopping for his and was tempted to just buy it myself after he got his red one.
EDIT - just found these gear ratio specs for the G8 A6 trans:
1st: 4.03
2nd: 2.36
3rd: 1.53
4th: 1.15
5th: 0.85
6th: 0.67
Looks like 4th or 5th will give similar numbers but third might throw it off a bit.
Old Feb 26, 2009 | 11:32 AM
Wow, check out the M6 gear ratios for the G8:
1st: 3.01
2nd: 2.07
3rd: 1.43
4th: 1.00
5th: 0.84
6th: 0.57
That is a steep first gear, even shorter than my MN12. I bet it will be a tire roaster with any sort of aftermarket gears with that kind of torque and that first gear. Everything else is the same as the MN12 except for sixth, which is a .56 in the MN12.
Old Feb 26, 2009 | 11:46 AM
registered user
I just noticed that you dynoed it in 3rd. I'm also curious as to how that will effect the numbers vs 4th gear. Let us know.
Old Feb 26, 2009 | 12:13 PM
Mike TexaSS's Avatar
8 Sec Tuner
I just tuned a 09 G8 A6. Stock it made 302 RWHP 322 RWTQ in 4th gear.
After tune. 320 RWHP 340 RWTQ.
Old Feb 26, 2009 | 01:18 PM
Wife now wants to come by after work to make the pull again, so we can keep track of what each mod is worth. I really like the color also, but think the white or black would have been our next choice.
Old Feb 26, 2009 | 02:22 PM
White is also awesome, but I personally couldn't turn down that blue color. Let us know how it does in fourth!
Old Feb 26, 2009 | 08:12 PM
registered user
Results like that make me want to get mine tuned real bad
Old Feb 26, 2009 | 08:17 PM
SS02's Avatar
Good stuff
Old Feb 26, 2009 | 08:57 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'm working on 1 right now.Made 304hp/320tq on my dyno in 4th.
After headers,pulley ect with stock mufflers it's at 326hp/345tq.
Be carefully on the tuning.I was able to get more hp with timing when not under a load but when loaded it would ping like a bastard.
Old Feb 26, 2009 | 09:45 PM
Default Numbers In 4th!!!
The 3rd gear pull was 313.73hp and 336.99tq on run file_004.drf - 2/24/2009 7:22:28 PM Run Type: RO Run Conditions: 68.70 F, 30.12 in-Hg, Humidity: 31%, SAE: 0.97
4th Gear Pulls: 319.45hp 346.97tq on Run File_005.dfr - 2/26/2009 6:28:21 PM Run type: RO Run Conditions: 81.22 F, 29.96 in-Hg, Humidity: 30%, SAE: 0.99
Next pull: 320.43hp 342.54tq on Run File_006.drf - 2/26/2009 6:48:37 PM Run Type: RO Run Conditions: 80.29 F, 29.96 in-Hg, Humidity: 32%, SAE: 0.99
Attached Thumbnails Base Line Pull 09 G8-dyno-sheet1.jpg   Base Line Pull 09 G8-dyno-sheet2.jpg
Old Feb 26, 2009 | 11:30 PM
One of our customers has ARH LT w/ mid pipes stock mufflers, powerbond pulley, rotofab CAI, MAF heat soak harness w/ IAT sensor, yank 3200, and tune made 365.60hp 375.24tq this was also a 3rd gear pull we will put it back on the dyno for 4th gear pull. He should pick up more than I did, cuz of mods.
Old Feb 26, 2009 | 11:51 PM
Skeet Skeet's Avatar
Damn those are some solid numbers. Congrats on the new car!
Old Feb 27, 2009 | 07:10 AM
registered user
Damn, that's alot of power! Is that totally stock, or with a tune?
Old Feb 27, 2009 | 07:43 AM
x2.
Slowhawk, what type of dyno? Are they SAE?
