Went to the dyno today
391.42 RWHP
373.46 Torque
Its strange, my car runs great, has no valve train noise and my butt dyno felt like I picked up 50 hp. I dont get it, I dont care if its a dyno queen but c'mon. Before anyone rags on the heads, keep in mind how low it has dyno'd already. Wish I would have had a stock baseline number.
First dyno tune with 228/230 .588 .592 on a 112 lsa.
LS6 intake, Patriot gold springs, Comp Hi Tek 7.4 push rods.
Yank SS 3200, LG Streets
367.61 Hp---360.16 Tq (netted me a 12.30@112)
Added 5.3 ported/polished , bigger valved, dual spring, ti retainer, 60 cc's,
Arp head studs
391.42 Hp--- 373.46 Tq
Maybe my valve springs are a little over kill? Tuner did say it was pulling a little vacuum, injectors were at 98% duty cycle, was getting enough fuel. My car is really tough to tune, usually takes hours.
Thoughts?
You got to remember that stalled auto's don't make the dyno numbers that m6's will with the same mods. However those stalled autos usually kick our *** all day long at the track.
Won't say much on the heads, but I'd definatly have waited until I could spend more money and have went a different direction. Heads are definately the mod to go $$$ on vs $ or $$. Your cam isn't very large so you are not going to make killer PEAK numbers, but your under the curve looks quite strong. The fuel might be an issue, are you still running stock inj's ?? 98% DC is cutting it too close in my opinion. Get a bigger injector so they can actually pulse vs basically staying on and just spraying. (That's the way high DC was explained to me, so correct me if I'm wrong) The ls6 intake is nice, but you have to remember the FAST 90, and 92's are out there for our cars, and with porting you could pick up 15 rwhp easily, and probably quite a bit more. LG streets are a great header, but you could've netted a few more with the lg pros. I don't see a catback listed in your sig, so open that sucker up and let her exhale. No ewp, or ud pully, so that's more power left on the table. Do you have the stock air box ? If so invest in a nice CAI. VaraRam may be crappy looking when it comes to quality, but you can't deny the results at the track. Now take my comments with a grain of salt, I am not saying anything negative, your car makes good power for what you have done so far, and keep in mind its a stalled auto, but if you were to finish it and add everything (Ported FAST 92, 90 or 92mm tb, 30# SVO inj's, EWP, UD Pully, lg pros vs streets, bullets catback <very loud>, and a cai) you'd probably pick up another 40 rwhp and 25 rwtq, maybe a little more. Now the next question is are you willing to pay in the range of 4000 or so (minus whatever you get from selling the lg streets, and ls6 intake) for an additional 40 rwhp and 25 rwtq ?? If so by all means break the bank, but your car sounds like a fun DD with a valvetrain thats going to hold up to the size of the cam for many miles with no worries or issues. Forgot something bro, you add that extra hp and tq, and you might have to upgrade other things too, like a built rear end, and those aren't cheap. If you want to go quicker leave the car as is and change the gears to 3.73's but I see you already have 3.42's so I don't know. Good luck and smile next time you light the tires up !!
You got a good reliable setup man, don't trade reliability for more peak hp.
Ask around, especially the guys cutting 1.4x's what tire they are running.
I feel your pain. I think I got a dog of an engine lol.
Your car should hit mid-11s if it's full weight with good tires without too much issue. Take a look at my car for comparison of power, ET/trap, and 60'. Mine is also a full-weight, wussy H/C car but I'm an M6 with a heavy drivetrain (12-bolt, 4.10s, MN12 trans, and a 3.5" driveshaft). Power output is probably reading similar on our cars considering, and with your auto/stall you should have no problem putting my track numbers to shame. Autos are just quicker at the track.
My 1/8 numbers are 7.5 @ 92, by the way.
And x3 on getting those injectors swapped out. I wish I knew what the duty cycle on mine were but never got it tested. I'm planning to upgrade the heads/cam down the road and it will require a fuel system upgrade anyways.
What head/cam are you running?
I put down 383 rwhp locked when I had a some 5.3L heads, 230/232 and a SY3500 stall
and ran 12.3x' @ 113 with a 1.9 sixty on nittos full weight car..
