heads and intake dyno
Old Mar 19, 2009 | 10:52 AM
1SPRY99's Avatar
Default heads and intake dyno
i went to columbus oh. last weekend to install my tea stage 2 ls6 heads and ls6 intake at my brother -n- laws place. after install we took it to a dyno and after him tuning it i got 377 hp and 382 tq. im very happy with the numbers. wondering what some other ls1's have put down with similar mods? the are milled to 61cc also
Old Mar 19, 2009 | 10:56 AM
1SPRY99's Avatar
that is with a stock cam.
Old Mar 19, 2009 | 11:08 AM
PewterScreaminMach's Avatar
With a stock cam the numbers look fine considering you're not really pushing them. Throw a cam in that thing and the pickup should be EXTREMELY significant. Without the cam, they're not getting the air and fuel they could really make the most of.
Old Mar 19, 2009 | 11:58 AM
1SPRY99's Avatar
i wanted to put a cam in it, but i bought the heads last fall when i was making decent money, now a different story and didnt want to buy all the other upgrades that go with the cam at this time. down the road for sure.
Old Mar 19, 2009 | 12:06 PM
1SPRY99's Avatar
here is the dyno sheet. i only had him print the best pull.
File Type: pdf
Old Mar 19, 2009 | 12:35 PM
sadegna's Avatar
put a cam in it
Old Mar 19, 2009 | 02:13 PM
Johnnystock's Avatar
Torque looks fun!! I bet the tire are spinning all the time!
..Of course a cam would be very nice!!
Old Mar 19, 2009 | 02:18 PM
allngn_c5's Avatar
Why ruin a perfectly reliable SLEEPER ?? A ud pully, and ewp might get you real close to 400 rwhp, and 400 rwtq, and the gas mileage is going to be awesome. Provided that you don't stomp her off the line all the time. About time somone did a heads only cam. I think one other person did too. Great results. You may not have 450 rwhp but you also don't have to worry about your springs, pretty much ever.
Old Mar 19, 2009 | 02:48 PM
1SPRY99's Avatar
thanks guys!!!! not sure what a ewp is though. and yes the rear bags are boilin
Old Mar 19, 2009 | 02:50 PM
1SPRY99's Avatar
electric water pump?
Old Mar 19, 2009 | 04:25 PM
allngn_c5's Avatar
yup !!!
Old Mar 19, 2009 | 04:34 PM
1SPRY99's Avatar
hey allngn c5 thats a bad *** car you have there. very nice
Old Mar 19, 2009 | 04:50 PM
ScreaminRedZ's Avatar
registered user
Very cool to see someone do this type of setup. I'd throw a set of 1.8 rockers on there with the previously mentioned pulley and EWP and it will probably pick up nicely. 400 rwhp in a car that idles like a stocker would make for a badass sleeper!
Old Mar 19, 2009 | 05:02 PM
1SPRY99's Avatar
the rockers arent a bad idea since im using the stock ones that have 120k on them. thanks for the info.
Old Mar 19, 2009 | 05:39 PM
01 MidMet WS6's Avatar
I love it!! I agree with allngn_c5. You will easily be able to slowly build your way to 400whp as your budget allows.
On the other hand even with a small cam the gains would be MASSIVE!
Old Mar 19, 2009 | 07:09 PM
1SPRY99's Avatar
i really want to put a 228/232 112 LSA cam in it. but thats down the road. i appreciate the suggestions about more upgrades. im not as informed as i should be and you guys have great ideas. thanks. as the budget will allow i will be adding. thanks
Old Mar 20, 2009 | 09:27 PM
allforspeed's Avatar
i think i'll probably end up doing this too, cause i'm out of money and like my gas mileage and don't want to ever change springs, i'll be using AFR heads with 1.8 rockers though, but i'll also only have MAC mid headers. good numbers and good to see it, i bet with a tiny cam that drives like stock, and a pulley you could easily hit 410rwhp or so.
Old Mar 20, 2009 | 09:30 PM
does that have ANYTHING else? man, you still got lots on the table i think, the pacesetter Y sucks ***, a new good one could easily be 5rwhp, port the throttle body and a 85mm MAF and maybe run some royal purple oil, get a under drive pulley, you may even hit 400rwhp with what you have there.
Old Mar 21, 2009 | 08:27 AM
1SPRY99's Avatar
everything is in the sig. i agree the pacesetter y does suck. im gonna mod as the income lets me. def doing an underdrive, ported tb. but i need to get the rear end done 1st. im on borrowed time now
Old Mar 21, 2009 | 01:32 PM
ExceSSive's Avatar
I think the rockers are the best idea. Probably the most bang for the buck at this point because it will make the stock cam think it is bigger. Then a cutout if you don't have one. Then the ported TB and the EWP. IMO
