Mustang Dyno #'s on pump 91 & meth
Number 2) Your single meth kit is fine.
Number 3) You need bigger injectors or a 2nd fuel pump.
Number 4) Your compression ratio is a time bomb for dissaster.
All in all, take care of your fuel system. You can pull to 6500+rpm and have more power. But, your compression is too high for forced induction. I see a motor rebuild in your near future. And maybe a rear end + a build tranny.
Sorry for the doom and gloom. Best of luck.
I have dual 255's in the tank, stock fuel lines/rails, and the 50lbs injectors. I dont expect my 10bolt to last much longer than the stickies going on the car, and I already have a built 4l80e in the car.
Thanks for the insight and luck.
Sell them on the board and maybe pick up some used ones for little or no money out of pocket.
I'm just waiting for my catch can to come in now to install it to hopfully keep from pushing past my rear-main seal again.(which happened this last time on dyno doing the 1/4 pass)
I was at KCIR this past saturday the da was around 2600ft
my best pass with a little wheel spin and shifting into od was a
1.71 60ft
7.02@103.31 1/8th
10.76@132.39 1/4th
