T-REX cam dyno results
Old Apr 10, 2009 | 03:34 PM
98LSZ28's Avatar
Default T-REX cam dyno results
What do you think? Mods in sig.
Old Apr 10, 2009 | 03:35 PM
98transamtx's Avatar
great numbers!
Old Apr 10, 2009 | 04:24 PM
LSXFORMULA99's Avatar
decent. mine looks something like that
Old Apr 10, 2009 | 04:31 PM
dug's Avatar
dug
strong numbers through an auto
Old Apr 10, 2009 | 04:39 PM
98LSZ28's Avatar
I'm happy with the numbers. I think my biggest drawback right now is the stock heads. The real proof will be at the track! I can't wait!!!
Old Apr 10, 2009 | 08:04 PM
moeZ28's Avatar
Your not gonna be happy with that stall speed...you need a looser converter. TREX doesnt really come on hard till after 4000 rpms.
Old Apr 10, 2009 | 08:14 PM
GMCtrk's Avatar
Why isn't the dyno SAE? I know Joe does SAE because both times I've dyno'd there they were SAE. 410 rwhp is great, I always thought that dyno read low as well.
Old Apr 11, 2009 | 06:25 AM
98LSZ28's Avatar
I have a 4000 vigilante on the way. I knew about the power band but dyno time is scarce there so I went with what I had for now, gonna put the 3400 in my sons car when I get the other one.
Old Apr 11, 2009 | 06:29 AM
98LSZ28's Avatar
Ok, I'm kinda retarded. What is SAE, and does it make a diffefence somehow?
Old Apr 11, 2009 | 06:50 AM
sujomatt's Avatar
SAE usually gives more power on a graph. SAE corrected numbers well do what it says - corrects the numbers to include pressure and temps and all that good stuff so if u were to take ur car to another place ud have similar numbers to compare... i guess is the easiest way to say it at 750am with no coffee lol
Old Apr 11, 2009 | 07:02 AM
98LSZ28's Avatar
So, if I understand correctly, my nimbers would have been slightly higher after correction for temp,density alt. and so on? Another local guy uses a different brand dyno and wants to strap down on my car to see how the dynojet compares to his. I think I might take him up on that.
Old Apr 11, 2009 | 07:14 AM
sujomatt's Avatar
Some info I found:
To convert raw horsepower and torque to SAE as given in SAE J1349 JUN90,
CF = 1.180[(29.235/Pd)((T + 459.67)/536.67)1/2] – 0.180
where PD is the dry air pressure (in Hg) corrected to sea level, and T is the ambient temp (in oF). STD is different from SAE simply because it uses a different set of environmental conditions, as shown below
The "old" definition for the so-called STD conditions were:
STD: T = 60 oF, Pd = 29.921 in Hg, RH = 0%, elevation = sea level
For SAE, the conditions are:
SAE: T = 77 oF, Pd = 29.235 in Hg, RH = 0%, elevation = sea level.
So from that definition of STD, to get STD from SAE, multiply by 1.047. To get SAE from STD, divide by 1.047. However, WinPEP v.6.03 software uses T = 68 oF for STD corrections, which results in 1/CF = 1.038. Some others define STD conditions as having T = 15 oC (= 59 oF). For example, the International Standard Atmosphere is T = 15 oC and PD = 1013.25 mb (=29.92 in Hg). The DynoJet Runviewer software v.7.0.1 uses still another definition for STD, which results in STD being about 2.1% higher than SAE. This is why there seems to be so much disagreement and confusion as to what the “correct” conversion factor is between STD and SAE. The problem lies in the fact that there doesn’t seem to be any real set definition for STD conditions. This is the main reason why I prefer to use SAE. Note - the difference between SAE and STD only depends on their relative definitions, not the actual ambient conditions. (Some have stated erroneously that the conversion from SAE to STD, or vice versa, depends on ambient conditions, which is not true. Ambient conditions only play a role in converting the uncorrected numbers to SAE or STD.)
Old Apr 11, 2009 | 07:28 AM
98LSZ28's Avatar
Some info I found:
Now my head hurts! LOL
Old Apr 11, 2009 | 07:36 AM
sujomatt's Avatar
MINE TOO! lol
Old Apr 11, 2009 | 11:32 AM
98camaroLS1M6's Avatar
Congrats on the numbers!
Old Apr 11, 2009 | 12:46 PM
NemeSS's Avatar
very good, it will pull hard thru the band
Old Apr 12, 2009 | 09:16 AM
98LSZ28's Avatar
Thanks guys! Unfortunately I think I may have transmission issues now! Seems to slip and slide sometimes, not sure if it is the converter or tranny.
Gonna go find a good lonely road somewhere and see if it holds up! Might b time for a 350/400 turbo?? Hate the thought of losing OD though.
Old Apr 12, 2009 | 09:23 AM
SLOW 94 LT1's Avatar
Not still the stock trans is it? I know you still have the 4L60E in there, but has it been modified at all? Take it to Chuck at FLT if you want to keep OD. He does GREAT work.
Old Apr 12, 2009 | 10:25 AM
Demonicbird00's Avatar
congrats on the numbers!! should be good for mid 11s
Old Apr 12, 2009 | 02:48 PM
98LSZ28's Avatar
Nope, it's not stock, beast sunshell,5 pin planets,aftermarket servo, supposed to be the good stuff! Might be the converter or in the electronics?? I have had a lot of electrical problems so far, sensors not reading right or intermittent etc.......
