Freak Cars
Old Jul 11, 2009 | 02:10 PM
  #61
Quick Sh0t xMLx's Avatar
Old thread just wanted to say one thing, no such thing as a freak car, only freak dynos. Take all your freak cars to the drag strip and none will trap what the power indicates it should.
Old Jul 12, 2009 | 10:53 AM
  #62
78novacaine's Avatar
320 rwhp and trapping 108 with a basically stock 110,000 mile ls1 intaked car blowing through a stock clutch
Originally Posted by 78novacaine
my car with 110,000 miles on it made 320 rwhp and 332 rwtq with only a lid and neutered catback. stock tune, stock ls1 intake, etc, etc. i think that's pretty healthy for a car with that many hard miles and so few mods. and it wasn't just a giving dyno that day either, i ran 12.8 @ 108 the night before on shitty kumho street radials cutting a 1.8x 60 ft. and the car hooks VERY well on the street. i dunno if that would be considered a freak, but it has put quite a few cars in their place that it shouldn't have (pulled on cam/bolt on cars off the line and held them off for 1/8 mile)
car now traps 110 consistently in 90+ degree weather and about 233% humidity, havent gotten it out in decent air yet, added longtubes and tsp duals, still untuned, still running an ls1 intake, just lid and exhaust. i figure that is about a 20 rwhp gain in the heat vs good air, should trap 111-112 or so come fall.
Old Jul 12, 2009 | 11:31 AM
  #63
BURN'EM's Avatar
I don't think it is a s much of freak cars rather than miscalibrated dynos and better drivers with good air. Back in 2001 my car had 147 miles when I took it to the track on the second day I owned it. All stock to the paper filter and not adjusting tire pressure. resulted in 8.47 @ 87 mph that's with an auto.
Now I know these cars have mileage on them now, that is why lite bolt on cars are the running the same times as I did years ago. Realistically you can't really compare them as freaks as they are 7-11 years old various mileage and most of you are not original owners, an do not know the care given for the car. 147 mile car then may be within the power possibilities of a lid exhaust car with 50k miles today after all of the carbon and wear has taken place over the years.
Dynos are just a tuning tool track times are close but varies on track prep D/A temp driver skills and condition of the car running car EX; condition of motor, trans, rear end,shocks ect.
Old Jul 15, 2009 | 08:51 AM
  #64
yarrie's Avatar
new #'s 1.56 60ft. 7.69@88.42 and chasing 7.40's. This is a true freak. temp. 86* and humid
Old Jul 15, 2009 | 09:30 PM
  #65
LPE Z Convt's Avatar
Originally Posted by speed_demon24
Sounds like you just dyno'd on an incredibly high reading dyno. It should be trapping a lot higher than that if it has 458rwhp.
Do the math its all about power to weight ratio. If the car weighed 3500 pounds it would be alot faster. I thought the dyno was reading to high but when the car was weighed in race trim vs. the times it ran the math works out.
Chris
Old Jul 16, 2009 | 05:06 PM
  #66
black01_WS6's Avatar
my car put down 319 stock, absoutly stock down to the paper filter. that was when it had 50k on it.
Old Jul 16, 2009 | 09:23 PM
  #67
HaulinHawk's Avatar
X2!!!! This is especially true for auto cars!!!
Old Aug 15, 2009 | 09:17 PM
  #68
Coreyc619's Avatar
a friend of mine ran 12.7 bone stock.(F body) we figured his car was a freak. no dyno numbers. his car is far far from stock these days. sure, hes a bit of a wheel man. without calling him to ask, i think his mph was just under 109
higher milage car (within reason of course.. not a 150K mile turd) should be faster than a 147 mile car. your rings were just beginning to get acquainted with your bores at that point dude.. as the motor wears some it requires less energy to turn, and better cylinder seal will produce more power.
Old Aug 15, 2009 | 09:53 PM
  #69
heymoej's Avatar
70100 mile 01 m6 camaro ss with pacesetters,gmmg,k & n cone filter,ported t-body,ls7 clutch,under drive crank pulley & a midwest fab9 rear with 410 gears sitting on pro star big & littles...
front & rear impact bars removed as well as spare tire & jack & thats it for weight reduction......
ran a 11.83 @ 115 with a 1.5? 60' in hot weather, 85 + if i remember right.
never been on a dyno,guessing 340 to the wheels ??????
i thought that was pretty damn good.
Old Aug 19, 2009 | 01:01 PM
  #70
KC Henry's Avatar
I wouldn't call it a "freak" since most of the 98 (F-Body) LS1's seem to dyno well. Making the same kind of Horsepower at the Rear wheels as GM rated them at the flywheel (305 hp back then).
My 98 (F-Body) LS1 dyno'd 316 RWHP with my electric cutout's closed, and 323 RWHP with the cutout's open. The motor is stock expect for headers needed to make the engine swap fit, and having someone remove the TQ Management, EGR, VATS and stuff from the factory GM "tune".
Here is my previous thread: https://ls1tech.com/forums/dynamomet...d-weekend.html
