2010 Camaro SS Texas Speed Underdrive Pulley Dyno Results!
We're proud to announce that we now have the Texas Speed & Performance 2010 Camaro SS underdrive pulley kits in stock & ready to ship!
This complete underdrive pulley kit features a 2010 Camaro SS underdrive pulley, new AC belt, new serpentine belt, and crankshaft bolt.
The TSP pulley kit has been designed so that you can bolt the package on in your garage with no lift or special tools!
The test car was a stock M6 car with only a catback. Pull 16 was stock with the Rumbler 5 catback, pull 19s only change was the pulley install!
Dyno results show 9hp & 8tq just by bolting on this kit!
The kits are in stock & available to ship today!!
Pricing for the complete kit is $249.99!!!
Pics:
![](http://www.precisionracecomponents.com/2010pulleykit.jpg)
Dyno Results:
Pics:
Dyno Results:
![](http://www.precisionracecomponents.com/2010pulleydyno.jpg)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LSxGuy widda 9sec Mustang
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The car is now back to stock other than the catback and pulley, did not test with the headers and induction, which were removed this week. Looking to confirm gains on individual parts rather than have peak numbers.
Pics:
Dyno Results:
Pics:
Dyno Results:
when you use underdrive pulley your voltage needle will drop a little and that when you have the stock 105 amp alternator. now if i upgrade the alternator to a 220 amp high output upgrade kit, i will not have this problem correct?
because my alternator took a shot and i have to rebuild it and i bought a 220 amp rebuild kit from :
http://www.springhillautoelectric.co...d&productId=37
part number cs130d-220a-ho-kit and thought i can use the underdrive pulley without loosing voltage with the 220 amp upgraded alternator.
Yeah, that definitely makes sense. What type of induction parts? I missed the info on those. Can't wait to see the results with the full barrage of bolt-ons!
Jason might post up the induction stuff later. It was worth around 12rwhp without tuning (over the stock setup); and tuning should not be required by putting it on a stock or mildly modified combo.
What is the REAL gain on these cars with a cat-back? The GTO and G8 was little to no difference (1-3HP) which could just be accounted as a temperature change while dynoing.
-Don
