Dyno graph, Thunder Solid Roller
Old Nov 4, 2003 | 05:42 PM
Camaroholic's Avatar
Default Dyno graph, Thunder Solid Roller
Well, after a long time in the process, below are the dyno graphs for the 'second phase' version of my solid roller 346 motor.
All numbers are through a Moser 12-bolt with 4.56 gears, 17" 5-spoke Speedlines with 275 Nitto DR's on them, a Denny's NR steel driveshaft, and with a short belt (I've got a manual rack).
When last I saw her, she put down 439/391 on Thunder's dyno (and 434/389 on LG's dyno in identical trim, for comparison ). Anyhow. We decided that wasn't enough, so Thunder had a new cam ground, some bullet mufflers instead of the Y/cutout, and we bolted on an electric water pump. The new results: 458 Hp, 410 Tq.
The previous cam was a 243.5/243.5 .646/.646 114 +4, to be exact.
The new cam is a 250/244 .646/.646 109 +6, or close to it.
So, we added 6 degrees of intake duration, left the exhaust about the same, and move the valve events around. I have yet to hear the motor (I pick it up this weekend right before the Shootout), but Geoff said it lopes "pretty hard". Especially since the exhaust has been removed for dual bullets.
We had planned to put new heads on, but ran in to issues with the new heads (p-to-v and compression ratio). So, we're running the same heads as before. Honestly, this set of heads isn't the bestest baddest set that have ever been done (we know that there are some issues with this particular set), but they do the trick. They're GTP LS6.
Some here may remember Jason's SR 346 that he ran to a 10.59 @ 128 with. Looks like mine has very similar characteristics. I'm VERY excited about that. I'm hoping Jason can teach me a few 6-speed tricks to shifting while we're at the Shootout. I've got a freshly rebuilt 6-speed ready to go in the car before this weekend. Let's see what happens. This is the Jason vs Andrew dyno graph...
I'm happy with the numbers, and I am REALLY looking forward to this weekend at the Shootout. Hopefully I can drive the car to some mid 11's, while Jason can hit some 10's with it. :p
To Thunder Racing. They've been absolutely great through all of this, and have REALLY gone out of their way to make me happy. I would DEFINITELY choose them again for my next build up. Now, Paul, get me an LSx Intake!
-Andrew
Oh, to be like this dude, he never misses a gear... ->
Old Nov 4, 2003 | 05:49 PM
mrhawk's Avatar
Nice numbers
Old Nov 4, 2003 | 05:54 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Very Sweet numbers buddy!
I can't wait to see it run this weekend.
Maybe I could get a shot at running some 10's in your Hot Rod.
I used to be able to drive a 6-speed.
See ya this weekend.
Coach
Old Nov 4, 2003 | 06:14 PM
jfm's Avatar
jfm
Very stout set up,kudos to Thunder and good luck at the Shoot out.
Old Nov 4, 2003 | 06:39 PM
gomer's Avatar
Highly impressive!! OMG, I bet that thing sounds wicked. Posts like yours makes me want to take the solid roller plunge.
Can you give the details of your shortblock? Crank? Rods? Pistons?
Thanks
Old Nov 4, 2003 | 07:07 PM
Thanks guys. I'm excited about the motor, and about this weekend. Now if Geoff would only open my bottle and spray the thing and get me some REAL dyno numbers.
Coach, if your shiftin' arm is feeling up to it, let me know when you're ready to take the keys.
As for the bottom end, it's a stock crank, Lunati ProMod rods, and Diamond pistons. ARP main and head studs, Katech oil pump, Jwis chain & Cloyes gears. The top end has T&D 1.7 rockers, 3/8" 7.4" pushrods, and some fat springs and trick retainers. Crane solid lifters. More ramblings in the pages linked to my sig.
-Andrew
Old Nov 4, 2003 | 08:15 PM
Damian's Avatar
LSX Mechanic
Andrew, you better learn how to drive real quick or a lil Futral setup is gonna come bitecha in the ***
Good luck man
Josh
Old Nov 4, 2003 | 08:46 PM
Tell him to bring it, and hope he brought enuff. Thunder's been doing more than just motor mods this last month, ya know.
-Andrew
Old Nov 4, 2003 | 09:01 PM
SMOKIN01TA's Avatar
looking forward to seeing how it runs this weekend, i saw it a few days ago a the shop, but i could stand under the hood so didn't hear much. yesterday i think they were putting some stuff back in the car when i was talking to jason so i guess the motor was in it. if have been debating on if i am going to be putting a solid roller or not, so far im not but im sure after sunday ill change my mind again.
P.S if you get bord at some point in time feel free to throw me the keys for a lil practice run with a solid roller. :-)
Rodney
Look for the white T/A smokin the ss/m class
Old Nov 4, 2003 | 09:55 PM
SMOKIN01TA's Avatar
and by the way jason has some good slicks, so if you want 10's, better bring a gallon of superglue for those nittos, i love my nittos but they wont pull no 1.4 60 fts.
Old Nov 4, 2003 | 10:23 PM
verbs's Avatar
Badass #'s!!! Just curious, what's causing that little dip in your dyno graph between 3700 and 4500rpms? Knock retard?
Old Nov 4, 2003 | 11:00 PM
SMOKIN01TA's Avatar
well verbs its nice to know i can expect 440 from my cam since your mods are almost identical. as for your question, he hasnt seen the car yet, but since the dip was only in the tq. curve its not a car problem. it looks like both his and jasons droped a bit at that point. probably just how the cam/motor combo puts out with their setups and mods.
Old Nov 5, 2003 | 03:07 AM
Solid346's Avatar
one fast question Sir, what is the bullet mufflers , and where do they connect... if you have pics of i that will be great.. the only reason am asking cause i am building a solid roller too. from your numbers the bullet made good power.
the other question is, will it be great in the street as more than 1/4 mile race.
Thanks
Hussain
Old Nov 5, 2003 | 06:11 AM
Hey Rodney, introduce yourself to me this weekend. Always good to meet folks.
As for Nittos... Those are my 'junker wheels'. I'd never run them. Those things are 5 years old and bald. I normally roll on Bogarts, and have 28" ET Drags for the strip.
KR is disabled in the PCM. So it's not knock retard, but it may very well be a tuning issue of some sort - too much, or not enough, spark advance. It's definitely one of the spots I want to investigate, I noticed it too.
Bullet mufflers are simply small mufflers. Check this out:
http://store.summitracing.com/partde...57#largerimage
I don't think that's the exact model we used, but it'll give you an idea of what they look like. My headers are ball flanged, so coming off the end of the header is a ball flange adapter, the bullet muffler, and a turndown. It's probably about 3 feet long total, each side. Cheap and light.
And as for on the street... If you like sideways in 4th, yeah, it's great (my street tires suck, and I don't street race). Nice to hit 7000+ in the morning getting on the freeway tho.
-Andrew
Old Nov 5, 2003 | 08:21 AM
Vents's Avatar
yeah... it is..
see ya there drew.
Old Nov 5, 2003 | 09:28 AM
BIGBOS's Avatar
Those are some impressive #'s, how does the car idle?
Old Nov 5, 2003 | 01:07 PM
ScreaminSS01's Avatar
Those numbers are stout. It will be enough to get you into the 10's for sure
Old Nov 5, 2003 | 01:30 PM
SMOKIN01TA's Avatar
hey Andrew, are you going to be bringing a camper, or will you be getting there on friday at some point. if so let me know. ill be there around 5 p.m to set up mine. and with 28" slicks, im sure you can get some 10 sec time slips. weather permitting of course.
Old Nov 5, 2003 | 02:47 PM
Maybe I can post up some sounds next week. I've not heard the car yet.
No, I'm roughing it Andrew style. I'm at the Gonzales Best Western. I roll out tomorrow morning, will be at Thunder mid-late tomorrow afternoon, construction on I10 permitting... Will be at Thunder most of Friday also, I think. We still have some work to do on the car (quickie tranny swap, and I've got the tranny with me).
-Andrew
Old Nov 5, 2003 | 05:59 PM
Vents's Avatar
should be there late friday night. we're @ the BW in gonzales as well.
