Are these #'s weak??
Old May 26, 2009 | 08:06 AM
burnout346's Avatar
Originally Posted by SS1875
Ran my car on a Portable Dyno (unsure of the name) during a tune party (non sponsor).
Car put down 466 RWHP/ 460 RWTQ NA
Car specs: 383 stroker, LS6 heads- 2.02/1.60 59cc ,Fast 90mm intake, NW 90mm TB, 236/242 624/609 113+3 JPH Cam, FTRA and 85mm Lid, 85mm MAF, T56, Strange 3" CMDS, MWC Fab 9" 3.89 gears, 17X11 ZR1's
My 383 put down 498.5rwhp & 541.7 on a dynojet , but that was with a stock rear with 4:10s and my heads are ported, polished & milled. What's your compression?
Old May 26, 2009 | 09:59 AM
SS1875's Avatar
11.2-1.... What supporting cast did/do you have?...I/E intake, cam etc. Are those NA numbers..no power adder? Big discrepancy in the torque (81.7 Ft/lbs) even for a Dynojet. On a Dynojet with my old cam, 12 bolt/ 4:10s and a ported Fast 90mm intake it only did 484rwhp/440rwtq.
Old May 26, 2009 | 12:43 PM
burnout346's Avatar
[QUOTE=SS1875;11656100]11.2-1.... What supporting cast did/do you have?...I/E intake, cam etc. Are those NA numbers..no power adder? Big discrepancy in the torque (81.7 Ft/lbs) even for a Dynojet. On a Dynojet with my old cam, 12 bolt/ 4:10s and a ported Fast 90mm intake it only did 484rwhp/440rwtq.
Air lid, MAF, ported TB, ls1 intake, stock injectors, mid length headers, off road y-pipe, cutout. All motor. Old setup.
Old May 26, 2009 | 12:48 PM
burnout346's Avatar
I found 3 loose plugs and a split plug wire after the dyno. Was also running lean. New setup is just upgraded to full length headers, true duels, 42# injectors, 9 inch!
Old May 26, 2009 | 12:49 PM
burnout346's Avatar
12.6:1 compression ratio.
Old May 26, 2009 | 01:04 PM
burnout346's Avatar
Ls1 243 castings.
Old May 26, 2009 | 03:49 PM
mike c.'s Avatar
They are strong #'s. same hp as my lil 346ci but your tq is much higher. a set of afr 205 heads would bring another 20hp or so.
Old May 26, 2009 | 04:28 PM
SS1875's Avatar
Thanks, the cam is more for the Nitrous setup so a little sacrifice is needed NA I suppose. If I decide Nitrous is not for me I will be thinking about different heads and the new cam would be on similar lobes but would get bumped to 252/258 630/630 112 (or something similar).
 Michael S. Palmer
Old Jun 2, 2009 | 11:00 PM
LS1powered09's Avatar
they look solid to me
Old Jun 2, 2009 | 11:59 PM
Dragframe's Avatar
i think those are good number from what i have read... those heads ported would make it a monster!
Old Jun 3, 2009 | 12:55 AM
krazy4's Avatar
I would be happy with those numbers.
**** dyno numbers, it's the track number that counts!
