LS2 with L92 heads makes 460rwhp/446rwtq
#61
And It runs like a bat out of hell! I was at the races this past weekend, in fact I first talked to you when you pulled into the show. I'm going with an LQ9, now that my LS1's gone. After seeing/hearing/watching your car, and talking with Pat G about the cam he spec'd for my LS1 going into the 6.0, I'm leaning towards the L92 heads!
Haha, well I beat my brother in his Z06 so I was happy. The car ran well. Definitely do the L92s, they are a piece of art. I can't believe that a factory cast head can perform that well; and I bought mine for only about $500!
#63
damn. that is exactly what i would like my torque curve to look like.
i think my next car, which will likely be a vette, is going to be going this route. If i dont put a maggie on it, that is.
#65
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
This combination hits at the heart of what the L92 heads are all about. Magnificent power curves with "old man" cams. The L76/LS3 intakes help accent low end and mid range torque. Nice work guys. I really enjoy seeing powerful street engines with near stock idle quality at a very low price point.
Richard![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Richard
Do WCCH have a plan to produce a L92 head that fit the 3.9 bore "LS1, 346ci"?
Thanks...
#67
This is interesting, Run of the mill L92 swaps on 6L are making 460rwhp. This one in particular with low compression. Get it up to 11 ish and there is 475. I have seen 228-232s make 460 with a comp bump through 4.11s and 230-234-114 make 480 with comp bump. And one of the sponsors has made over 500, with the latest WCCH heads and FAST manifold. Some shops here making 500 with a 237-243 on 111+0 on stock comp although low end is terrible! 12:1 comp is then required, Pats setup with better ex deleted MAF and more comp would be at 480hp and eat the big cam under the curve. RPM motors have been still using the 224-228 114 xer cam getting 470. same cam propelled SS Enforcers VE-G8 to 11.6@119 mph full weight still has not been matched.
#68
Can you show me the link..dont think its out yet. Didnt find on their site.
I think its only MAST that has these kind of heads but at an outragous price. Better stick with TFS/AFR for the same price IMO. I checked out and its 1300$ for unassembled EACH!!!! But they flow damn great I'd say; 353/257 at 700 lift
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
#69
Interesting build. I'm a 4x4 guy with an LS2 going into a buggy right now. Just as a point of reference, in a car like that about what would the power be at the crank? RWHP means little in a buggy with a t-case behind the trans, 6.72:1 reduction in the axles and 47" tires.
Very impressive dyno. I was planning to leave my engine stock for now but given the affordability of such a mod may just go ahead and do this and be done with it.
J. J.
J. J.
#70
I found it on the GMPP
They specifiy it for 3.9" bore, but it is not CNC
They don't have a price tag for yet...
In order to find it, you need to brows the GMPP catalog under the LS heads...
http://www.gmperformanceparts.com/_r...09_Catalog.pdf
Congratulation to the customer and Patrik G (Cam Dr.) ...
MRT
#76
A fast 460 rwhp ls2(100+rwhp over stock) on a cheap budget build like that? **** thats freakin amazing to me...A set of trick flows probaby cost more than the entire build
Im not a fan of budget builds personally but i mean damn that is a lot of bang for the buck imo....
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#77
LSX-L92 Small Bore Cylinder Head (not shown)
• L92 style rectangle port design
• Assembled with 2.00" intake and 1.55" exhaust valves
• 15° valve angle
• Minimum 3.89" bore
• 250cc "as-cast" intake ports, 80cc "as-cast" exhaust ports
• 65cc "as-cast" combustion chambers
• Responds well to larger valves
#79
If I put this heads, cam, intake, tb combo on my iron block 6.0 I should see similar numbers right? Or is there something I'm missing? I really like seeing over 350ft lbs at 2300 rpm!
#80
As long as your 6.0L is an LQ9 with flat top pistons like the LS2 6.0L block that Kevin used in this build. Most 6.0L iron blocks are lower compression LQ4s and they will limit the torque and hp ability compared to the LQ9s.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
The following users liked this post:
Stefan N (06-08-2020)
