afr 225 ms4 dyno
Old Jun 29, 2009 | 05:01 PM
johnster's Avatar
Default afr 225 ms4 dyno
i got my car dyno'd 2 day and i was happy with the out come, considering it was 94 outside, 1st pull is unlock,2nd is locked
ls6 block, flycut piston
afr 225 small bore heads mill 2 59cc .40 head gaskets
ms4 cam
36lb injectors
ls7 lifters
stock rockers
comp pushrods
ported fast 90 2 100mm
rev xtreme 100mm tb
100mm tsp maf
1 7/8 tsp long tubes
power bond pulley 25%
3 inch duals x pipe
3.73 out back
built 4l60e 4k stall
what you guys think?
Old Jun 29, 2009 | 05:02 PM
Chris81's Avatar
Thats pretty damn stout through an auto.. that thing should haul ***!
Old Jun 29, 2009 | 05:04 PM
RARON455's Avatar
good numbers bro.. it should haul
Old Jun 29, 2009 | 05:05 PM
Gordon0652's Avatar
Not bad numbers at all.
Old Jun 29, 2009 | 05:19 PM
Dennis@SpectacleSolutions's Avatar
LS1Tech Sponsor
Thrilled you are happy with it John.
Get that thing to hook and let us know the results. Bring it to Memphis for TnT one night and lest us know. Id love to see you make a few passes.
Old Jun 29, 2009 | 05:58 PM
ROCNDAV's Avatar
Good to see some of my parts finally get put to good use! great numbers!
Old Jun 29, 2009 | 06:19 PM
johnster's Avatar
jeff what nite do they have it????
Old Jun 29, 2009 | 07:05 PM
RJB01camaross's Avatar
Great numbers!!!! Should produce some good times at the track
Old Jun 29, 2009 | 09:07 PM
6LTRiceater's Avatar
great numbers!
Old Jun 30, 2009 | 12:11 AM
Spectre86's Avatar
ms4 cam
36lb injectors
ls7 lifters
stock rockers
comp pushrods
rev xtreme 100mm tb
100mm tsp maf
3 inch duals x pipe
3.73 out back
talk about a top end runner. damn near 470rwhp through an auto. congrats man. any videos?
Old Jun 30, 2009 | 12:41 AM
venom ws7's Avatar
Damn awesome setup man Congrats with the drivetrain WOW.
Take some weight out of that thing go run some 10s
if that car had an M6 I see 490rwhp for sure
Old Jun 30, 2009 | 01:23 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Is that an original fast 90 that is opened to 100mm or one of the newer 92s? Have any pictures of it? DOes it still use the o ring gasket or a paper one?
Old Jun 30, 2009 | 06:08 AM
LS1Tech Sponsor
check out memphismotorsportspark.com for the schedule.
I havent checked it in a while but its thursdays with some tuesdays thrown in at times.
and I believe they are doing several friday night "midnight madness" sessions this year as well.
Old Jun 30, 2009 | 08:45 AM
johnster's Avatar
the intake is a old fast 90,the runners have been ported and sanded.
i have a post in the generation 3 external engine where i ported the intake out to 100mm, there r pics there, u cant use the o-ring, i used some gasket maker called {the right stuff} u can get it at any parts store
Old Jun 30, 2009 | 08:48 AM
johnster's Avatar
ill try to get a video of the car
thanks guys she does pull like a train from 4k up
Old Jun 30, 2009 | 08:58 AM
firefighter813x's Avatar
They make AFR 225's for the smaller 346 bore? Didn't know that.
Old Jun 30, 2009 | 09:10 AM
86 IROC's Avatar
Thumbs up
Nice, my car layed down similar #'s and has some of the same parts. 1/4 mile time and trap speed in sig. My car is still heavy, 3540-ish w/o driver. I'm 175-180 @ "race weight."
Old Jun 30, 2009 | 09:28 AM
johnster's Avatar
iv taken some weight off her, she 3280 without me in it, im about 200 pounds around 3480 with me in it
rpmauto's Avatar
awesome #s for a auto, makes me want to get some better heads and cam for my 402
Old Jun 30, 2009 | 09:57 AM
86 IROC's Avatar
It should run strong, I swapped to a 28" tire and the car hooked hard/got deadly consistent. I'll be changing my converter next, it should 60' better than it does.
