Our latest LT1 396
Old Jun 30, 2009 | 11:50 AM
JasonShort's Avatar
Moderator
Great numbers! The LT1 is capable of making great power with the right parts. AI heads are stellar
Jason
Old Jun 30, 2009 | 11:56 AM
Speed Density's Avatar
hashtagBMW
471rw is a solid number, very nice.
Old Jun 30, 2009 | 12:03 PM
Damian's Avatar
LSX Mechanic
Damn. 470/440 is a stout #. I bet that thing is a blast to drive. 350 ft lbs @ 2500
Old Jun 30, 2009 | 04:10 PM
edcmat-l1's Avatar
Yeah it is. It pulls nice. Very responsive!!
Old Jun 30, 2009 | 04:39 PM
Racin96ss's Avatar
Very nice #'s
Old Jun 30, 2009 | 05:05 PM
ScreaminRedZ's Avatar
registered user
Amazing numbers!
Originally Posted by JS
Nothing wrong with an LT1
Don't say that...then people won't underestimate them and it won't be as funny when they get their *** kicked by one
Old Jun 30, 2009 | 08:45 PM
Abdullah's Avatar
Originally Posted by edcmat-l1
We just got done with a LT1 build. 396, Eagle crank, Compstar rods, Mahle pistons. Custom cam, our spec. Edelbrock intake, AI heads. They were already on the customers previous engine.
New clutch, new headers, new exhaust system, new 255 fuel pump.
I like the AI heads ALOT!
This was the last pull this evening. It was pretty well heat soaked. It pulled a bunch of timing. That's the reason for for the step in the graph lines. We'll do a couple hero pulls in the AM.
great numbers for LT1. are the heads the AI CNC 200cc GM LT1 heads? what are the cam specs? compression? other mods...etc?
thanks.
Old Jun 30, 2009 | 08:49 PM
Abdullah's Avatar
Live, from the dyno!!!! Final numbers.........
btw, is the hydraulic roller or solid roller cam?
even greater numbers than in the first post.
Old Jun 30, 2009 | 08:55 PM
Shawn @ VA Speed's Avatar
AI 200cc gm heads
hyd roller cam mid 240's low 250's
edelbrock intake-not ported
Old Jun 30, 2009 | 09:09 PM
Tireburnin's Avatar
Stock ported LT1 heads and a HR cam 396 = 471rwhp WHEN YOU USE THE RIGHT PARTS AND PEOPLE FOR A SETUP.
Good job on the numbers.
Old Jun 30, 2009 | 10:34 PM
BADMOON's Avatar
Originally Posted by Shawn @ VA Speed
AI 200cc gm heads
Thats pretty much the same setup mine has.
same intake same size cam. but mines a 383. What do the heads flow at .600 lift? I am guessin this is a stock computer?
Old Jul 1, 2009 | 07:46 AM
  #32
edcmat-l1's Avatar
Yes on the computer. Don't know the flow numbers. Maybe AI will chime in.
Old Jul 1, 2009 | 07:50 AM
  #33
Advanced Induction's Avatar
Smile
Skilled/experienced labor is just as important as the quality of the individual components. Unfortunately, many 'save money' in those areas. When the setup simply runs to its potential it is often labeled an anomaly.
That is a slightly older version of the 200cc head from ~2.5 years ago. Probably 27Xcfm, but please understand that flow #'s are neither directly indicative of power potential, nor are they comparable. Meaning, it is futile to attempt to correlate X hp with X cfm to the exclusion of every other variable in the inlet tract. Much less every other variable in the engine, tuning, drivetrain, etc.
Old Jul 1, 2009 | 04:04 PM
  #34
BADMOON's Avatar
From the man himself My heads are Trickflows. Got the same size cam. This car is probably a 6 spd like mine judging by the numbers.
This makes me wanna send my heads to you even more.
And let the OP take a crack at tuning my car. I know more cubes = more torque but I wanna squeeze some good solid numbers out of my 383 and keep it a Hyd roller.
Hey ED we never found out what compression this car is running?
Old Jul 1, 2009 | 04:07 PM
  #35
BADMOON's Avatar
Default Also
I would love to see some vids of this car whoopin up on some LS1's.
Old Jul 1, 2009 | 06:23 PM
  #36
edcmat-l1's Avatar
11.6:1.
BTW, there's alot to be said for a good LT tune. A GOOD tune on one of these things takes alot longer than an LS tune does. The software is not near as user friendly. VE tuning is pretty painful to get right. I've set a bunch of these things up to run SD instead of MAF. But, like I say it's painful.
Old Jul 1, 2009 | 11:07 PM
  #37
Abdullah's Avatar
you said these dyno numbers on stock PCM, what car is this? and what year?
thanks.
Old Jul 2, 2009 | 12:19 PM
  #38
edcmat-l1's Avatar
thanks.
95 Camaro.
Old Jul 2, 2009 | 04:22 PM
  #39
BADMOON's Avatar
95 Camaro.
Wish you were closer. I heard Moe Bailey is also pretty badass on LTX tuning like you and he is 3 hrs from me . Do you know of him? By the way, when you were talking about tuning not on MAF but SD, What is SD? When you say painful do you mean money $$$$ or is it just a pain in the *** and someone needs to know exactly what they are doing?
Thanks
Old Jul 2, 2009 | 05:25 PM
  #40
edcmat-l1's Avatar
Thanks
Don't know Moe Bailey.
SD is speed density. It's a pain in that the software is antiquated. It takes a long time to transpose the numbers from a run log to the tune, flash ,and repeat. If done correctly, it takes longer than an LS tune, and should cost more.
