Svt bait
Nice pics and vid man. I got an idea. You next video should be of the girls washing your car !!!!!!!!! Can I get someone to second it ??
I will probably be dropping you a line later for some more info on your install. Catc ya later
i put down 436rwhp and 388rwtq on a mustang dyno(with done stock 243's) so get that valve train right and fix them 02's and see what it will really do there should be more then 20 left in it
I talked to Brian from TEA a bit about your car and he suggested you check the valve covers for adequate clearance.
Also, maybe you f-body guys can chime in, but are the SLP headers any good? Could the cats and the Y-pipe be affecting your torque?
I have been under the impression that the SLP headers leave alot to be desired.
Other than valve float I don't understand why the power went flat from 6000 to 6600. There has to be a cork somewhere. What about the stock 75mm MAF?
As a side note-Champions dyno reads on the low side-about 10 rwhp lower compared to other dyno's in the area.
I would like to see 450 rwhp at least.
It really wasn't all too hard at all. I took my time and (almost) everything worked perfectly.
Feel free to PM/email/call me with any questions!
Once everything gets sorted out, I'll get rid of the cats and get a bigger MAF and lid. Hopefully with everything all said and done we'll be able to see 475.
The first drive was ridiculous. I put the car sideways on the on-ramp.
I'll take a look this week and try and find out what's up. When I take the covers off I'll look to see if there are any marks on them from the rockers.
I'll inspect everything and let you know what I find out. Hopefully it's something simple.
Just for the record my AFR was perfect other than at startup and coasting down long hills in 6th gear. In both cases, it leaned out.
I think that I'll get rid of my cats once this is all sorted out. It's not like they are doing much other than hurting horsepower.
My buddy's 02 SS has similar setup to yours except the heads milled to 59cc final numbers were 458rwhp/421rwtq through noisy Borla Catback so with cutout that thing gonna gain 10/8 least so 468rwhp/429rwtq on the way
peace
Go back and remeasure your pushrod length, if the length required is different than what you've got, thats where your power after 6K is going.
