383 Question
Old Jul 17, 2009 | 04:53 AM
TransAm2002's Avatar
Default 383 Question
I am looking into doing a 383 in the near future. Compression will be around 11.4-11.5. I will be using my PRC 5.3 stage 2.5 heads and MS3 cam with this set up. I am also adding a Fast 92. Do you think I will be close to 500 RWHP and 460 RWTQ? Should I go with a bigger cam? Car is a street car that hits the track in the winter. Also will be putting a 200-250 through a Nitrous Dave's plate until I can get a stand alone and direct port set up. Thanks for any replies.
Old Jul 17, 2009 | 06:14 AM
burnout346's Avatar
I think you should be close to 500rwhp. Your torque should be more than 460. I run a slightly bigger cam and more compression and put down 541.7RWTQ.
Old Jul 17, 2009 | 06:37 AM
cbra-klla's Avatar
My 383 is almost done. Compression is 13.75 to 1 with a 244 254 cam. I'm more worried about track times though
Old Jul 17, 2009 | 07:50 AM
ssZL402's Avatar
i think you should consider either a 402 or 408 torque requires cubes and u dont want to max your motor out that fast they make big blocks for a reason
Old Jul 17, 2009 | 12:17 PM
XS HP's Avatar
I agree brandon. After our conversation the other day, I would say that you should go with a 402 or 408. If you are already spending a few thousand on a new block, might as well take the next step completely and make sure you are well into the 500's.
Old Jul 17, 2009 | 12:36 PM
allngn_c5's Avatar
As the old addage goes, theres no replacement for displacement.
See sig for some nice tips on daily driveable N/A power. Track times coming soon.
Old Jul 17, 2009 | 05:23 PM
Vindicated346's Avatar
maybe im reading this wrong or something, but are you referring to a 402 or 408 LSX as a "big block"?
Old Jul 17, 2009 | 10:54 PM
viper,redZ's Avatar
Ok got a ? to add if I build a 383 aluminum block and it made say 460-500 hp and I built a 402-408 iron block and it made 500-540 hp. Do u really think the 402 car would be that much faster . Yes I know the torque would be different but the 80-100lbs weight difference seems like it would make up the hp/tq difference . Like I said its a ? not an opion
 Michael S. Palmer
Old Jul 18, 2009 | 02:03 AM
caviness's Avatar
aluminum 402 no weight difference and 40 or 50hp or tq will make a little difference.
Old Jul 18, 2009 | 10:49 AM
viper,redZ's Avatar
In that case I understand but how many people can go out and buy and aliuminum 402 ? I saying in the real world iron 408 vs aluminum 383 .
Old Jul 18, 2009 | 11:17 AM
allngn_c5's Avatar
I'd still take the IRON 408 based on the block strength factor. The iron block will take a lot more then an aluminum based 383. JMHO
Old Jul 18, 2009 | 12:07 PM
viper,redZ's Avatar
Then why did you build a ls2 ? That kinda contradicted your statement above . I know the iron block will be durable but if u making 500-550 rwhp durability does not come into play imo .
Old Jul 18, 2009 | 03:00 PM
allngn_c5's Avatar
Not at all. Re Read the question above my comment. He asksed 383 aluminum vs 408 iron. 402 aluminum wasn't a choice. If it was, I would've picked ls2 402. I also believe the poster was referring to using an ls1 aluminum block with a 4 inch crank to make his 383. Aluminum LS2 block strength is greater then the aluminum ls1. I hope that clears up your misunderstanding.
Old Jul 18, 2009 | 04:22 PM
Michael02hawk's Avatar
I've been running a stroked 383 LS6 block in my Trans AM for 5 years now. I am putting down the EXACT numbers your quoting above!
My compression is right at 11.4!
See my sig/web link for the details of my setup.
Old Jul 19, 2009 | 08:14 AM
Wow, sounds good. Very nice set up you have.
Old Jul 19, 2009 | 09:59 AM
Thanks - I love this car of mine!
It's streetable,
Just loud enough to get attention,
a head turner,
...oh yeah, and Fast!
It's not a sleeper, but people just dont realize what it can do.
...very few that pull up next to me wins (or even tries)....very few.
Old Jul 19, 2009 | 10:04 AM
383lt1impala's Avatar
I think u will be close. I would go with a custom grind. Hopefully I can hit over 500rwhp. My set up is a
383 ls1 forged bottom end.
12.56 to 1 compression
Good ported 806s.
Victor jr with 4 barrel tb.
Ms4 cam with 112lsa.
I also plan to shoot a 300shot in it. It should make my impala move!!!
Old Jul 20, 2009 | 03:01 AM
SS DNA's Avatar
It's streetable,
a head turner,
Is there any idle videos of your car ?
Old Jul 20, 2009 | 03:30 AM
Johnnystock's Avatar
Alum 402 is not that much pricier than a iron 408. 500-800$ more at most. and yes I would take an iron 408 before a 383. But thats me
Old Jul 23, 2009 | 08:33 AM
Sigforty's Avatar
https://ls1tech.com/forums/dynamomet...t-results.html
Sounds like you want to do what I did. Here is my setup if you care to look at some numbers.
