ls1 500HP?
Old Aug 5, 2009 | 12:08 AM
javier1730's Avatar
Default ls1 500HP?
so..i bought i set of AFR 205's 66cc with a ported FAST 92/92mm...still undecided on the cam but, the build suggested a 610"/619"....also Fast Toys ram air kit ,slp underdrive pulleys and a 175 wet shot..all this on a 98 z28 m6...is it possible to get to without the nos? 500hp....also any suggestion on the cam since i haven't got one yet ,i thinks this will be a good time to take advice from someone experience before getting one. thanks
Old Aug 5, 2009 | 05:12 AM
9secondsflat's Avatar
tony got 530+ but his was a 383 and a solid roller...i have not read of many afr heads using a hydrolic roller cam break the 500....
Old Aug 5, 2009 | 08:10 AM
00T/AWS6's Avatar
build looks good, i think you will definitly be high 400's with the right sized cam but 500 is a hard number to crack. I'd have patrick g spec you a cam, he is the cam guru. Also i believe he had a 500 hp motor car
Old Aug 5, 2009 | 12:31 PM
caviness's Avatar
one example i found,,https://ls1tech.com/forums/generatio...heads-cam.html
Old Aug 5, 2009 | 02:04 PM
MelScrilla's Avatar
that damn 500hp 346 is sweet but the parts required cost to much. I would be happy with some 215's a good cam and 470 through a stalled A4.
Old Aug 5, 2009 | 02:47 PM
Omega Doom's Avatar
damn I made 414rwhp locked with just a cam,full exhaust,stall and a tune only! stock intake,block,heads etc... so why would 500rwhp be so tuff with heads custom cam,fast intake,EWP,pulley etc.... ???
Old Aug 5, 2009 | 03:04 PM
JayplaySS's Avatar
Moderator
I think the guy may be talking 500 engine, not rwhp but who knows. 500rwhp is not an easy feat but very possible. I would go with TFS's though.
Find somebody's 500rwhp build and duplicate it exactly.
Old Aug 5, 2009 | 04:30 PM
Mike@HSW's Avatar
here is our 500+ combo. Pricey, ya a bit. Especially being in the nitrous industry when you could spend half the money and add a small amount of spray to get the same results. Either way that combo should be repeatable. results below were 492, but with the cutout finanly installed it picked up a lot and went well over 500.
https://ls1tech.com/forums/dynamomet...c-results.html
Old Aug 5, 2009 | 05:09 PM
RJB01camaross's Avatar
There are lots of proven combos that have been put together to break 500rwhp, best thing to do is contact one of the sponsers and tell them your goals.
Old Aug 5, 2009 | 05:35 PM
javier1730's Avatar
well, my goals are 500hp motor...im just wondering if that could be achived with the parts i got plus a good cam
Old Aug 5, 2009 | 07:01 PM
djfury05's Avatar
very possible.. try about 550+hp to the crank with ur setup
Old Aug 6, 2009 | 01:06 PM
slt200mph's Avatar
500 HP at the crank is not hard to do but 500 to the rear wheels with 346 cubic inches of engine is a different story...bring lots of money the last 30 HP is expensive to do...I didn't want to spend the money and settled for 452/418 and still get 27.5 MPG on the highway as a daily driver.
To omega doom who made 414 HP that is the EZ half of the formula to get to 500 HP the next half especially the last 25 to 30 is the hard part .... read Patrick G's thread on how to get to 500 RWHP and you will see how it is done...It is listed in the 4th post of this thread (the recipe to 500 rwhp) ...a good selection of high quality mods that compliment each other and attention to details get you to the goal ... if it was EZ everyone would be doing it...
Old Aug 6, 2009 | 01:49 PM
Martin HD-28's Avatar
Check out the mods in my sig, call Speed inc. and talk to Larry.
Old Aug 6, 2009 | 01:54 PM
miller456's Avatar
now are these 500+ numbers coming from a dyno jet or a mustang dyno?
Old Aug 6, 2009 | 04:56 PM
call chris at ecs...they have built several stock bottom end 346 that top 500 rwp...
http://www.youtube.com/watch?v=GlU4i...x=0&playnext=1
Old Aug 6, 2009 | 08:28 PM
MelScrilla's Avatar
it seems like lots fo people do it but the money it takes is pretty crazy. I think its most for bragging rights. I'd save the money and put it towards a stroker, that way you'll be well past 500.
Old Aug 6, 2009 | 09:04 PM
30th t/a's Avatar
how come it is more common to see 500rwhp out of a 346 which is 1.44rwhp/per cube over a 580rwhp 402 stroker, which is the same 1.44rwhp per cube???
Old Aug 6, 2009 | 10:40 PM
javier1730's Avatar
it will be in a dyno jet....i know some people have done it, and i know it takes a lot of knowlege, money(specially), and time....also im planning on getting a lq4 stroker since i'll be spraying the car..but i havent got the block yet.
Old Aug 7, 2009 | 09:22 PM
MelScrilla's Avatar
I think the thing that would be most impressive is to see someone do 500rwhp with a stalled A4. Then I would be impressed.
Old Aug 10, 2009 | 01:25 PM
fasttagurl's Avatar
Ok, ok. Be impressed: I have the set-up you're talking about.
By Brett Foote | 2026-06-04 05:00:17
