402 w/ L92 heads... another wrong cam
If my "setup" was in a more suitable "drag car" it would pick up quite a bit-not 135mph but considerably better.
Can only guess at what the cam would do with this setup in a stroker.
Kooks 1 7/8 headers w/ cats
LS3 intake and Manley race exhaust valves
Stage 2 port job on the intake manifold done by me!
Not sure what did what, but I'm happy with the results... I will be heading back to the dyno once I do more tuning.
Speaking for my self, this is an achievement for the 402 ci... It made more to go with the L92 head for their potentail since comparing cost vs results is ranked real high... Really GM engineers done their work well...
As for my question, I read about L92 head from other threads, that it has exellent intake flow (+300 cfm @ 0.600") in the stock form but the exhaust flow is not to the level of the intake, thus I'm assuming massaging the exhaust by porting will help this issue or it will make it worse...
Buy the way, do you have plan to use vaccum pump to pump the rwhp up more...
MRT
As far as the vacuum pump, I'm still reading into that one. There isn't alot of information out there on it. Might be worth doing though....
(posted in response to a previous comment on there 402 didn't pick up any power when switching to a larger primary)
Ron sent me a replacement pair and now she is running perfect. Kicking *** and taking names. How convenient though, she's running great, and its time to put her up for the year. I plan to drive her this weekend and then who knows. As long as a couple sunny days are in the forecast with no snow I'll drive the car. Scary how much harder she pulls on the COLD air.
