Retune ?????
The Z06 cam is a very minor step up over stock, so minor most people wouldnt even bother swapping it..........
The only other mods the car has are headers, a lid and a slp cold air induction , I dont understand why everyone thinks the car should make so much power??
Look at what 01/02 Z06 Vettes put down bone stock (right around 340rwhp-350rwhp), so if this car has basically the same set up but has a A4 instead of a M6 (figure in the drivetrain loss of aprox 18%) how are the numbers that far off?
Now look at the trap speed in the 1/8th and what stock Z06s run (about 7.9 @ 89mph) and thats through a M6, a good stall convertor will put this car into the 7s
Maybe part of the problem is (and I told you this Butch) the car is on the stock plug wires at 100k+ miles................
I'd be willing to bet changing the wires would close the gap by a few HP.
The car does have new plugs, new O2s , new fuel filter ect
The car was tuned at New Era by Mike and I saw the dyno sheets when I was up there with my 2010, the afr was fine
Mike has the dyno sheets, I dont know why he didnt print them for you but I'm sure if you call or email him he will get them to you asap but personally I think the numbers are about dead on for a basically stock "Z06" motor through a stock 4L60E, anyone have solid evidence as to why its not???
I dont think the results at the track were that bad, I ran a 7.5 the Camaro I sold Lee but I dont think I broke below a 8 the first 2 times I was at the track with it, Lancaster is also known to be a tenth or two slower than other tracks due to the fact it goes uphill....................
My old 98 Formula with lid, pacesetters, magnaflow catback and drag radials only ran a 8.6@ 84mph and that was with dozens of runs and those numbers coming in late september.............
I think the dyno numbers might be 10-15hp off but then again it does have over 100k on the car and the plug wires are original
Like I showed you theres also alot of weight savings in that car to be had and I hate to say it but your never going to get the times you want without a stall..................................
Summary-
theres a tenth or two to be had in weight savings
theres a tenth or two between new plug wires, porting the TB and maybe some adjustable drag shocks
theres about half a second on the table with a stall
and theres probably 3-4 tenths with more practice
but most importantly its all about having fun
I saw the car on Abbott road about a month ago and it looked bad *** with those rims on it
Summary-
