APS C5 Mild Street Build
Old Sep 14, 2009 | 07:54 PM
Fastbird93's Avatar
Default APS C5 Mild Street Build
This is NOT a max effort build, and I'm honestly very pleasantly surprised at the outcome. Some thought and planning went into speccing the motor and it paid off. Nothing outlandish, setup is as follows:
APS TT, only mod being filters directly on turbo's, inlets completely removed.
TSP 377 short, set up 9.25 SCR
Cometic 4.010 head gaskets
Patriot Stg 2.5 317's
Lingenfelter GT2-3 Camshaft
Lonnies Double Pumper fuel system
97-98 Rail Conversion
60# Mototron squirters
LS6 Manifold
Ported TB
ECS Alky Control Meth Kit (100% meth for now)
Stock 97-99 MAF (still screened)
Joe P Pro-Z Manual Boost Controller
Powerbond Underdrive Pulley
160* Thermostat
PBJ Tuning
Car drives and sounds stock (with a cat-back). It's quiet, smooth, and devilishly fast when the go pedal is pressed. There is a large inefficiency in teh APS twin IC's on the C5, IAT's were HIGH unfortunately. Boost is set at 14lbs, it peaks to 14.4 for a short time then settles at about 13.9 for the duration. Turbo's smoke only minimally after a full hard pull, which is surprising considering the oil they dump when I have the manifolds unbolted and the turbo's tilted down. Anyway, here's the end results:
760 RWHP, 761 RWTQ. I'm happy as a chopstick in rice.
Old Sep 14, 2009 | 08:30 PM
Pipelayaz's Avatar
"Mild street build" lmao.. nice number man!
Old Sep 14, 2009 | 08:31 PM
ScreaminRedZ's Avatar
registered user
Damn, those are some serious numbers! For a car that you say will drive and sound pretty much stock, that's insane!
Old Sep 14, 2009 | 08:59 PM
RJB01camaross's Avatar
Sweet numbers!!!
Old Sep 14, 2009 | 11:05 PM
tomz28's Avatar
mild my *** bro
how high are the iats they cant be that high with the meth. i drop 30 degs with my meth
nice numbers
Old Sep 14, 2009 | 11:11 PM
Fastbird93's Avatar
Seriously. It's nothing fancy. Budget parts, nothing outlandish, car externally passes for a lightly touched car, and with the hood open there's not much to see.
Thanks all! I'm pretty happy about this (having ONE good car finally).
Old Sep 15, 2009 | 03:34 AM
venom ws7's Avatar
Mild street my ***
LOL
Congrats man awesome numbers.
Old Sep 15, 2009 | 12:21 PM
LS1 SPEED's Avatar
looks like you got with your tuner after all
#'s look real good..congrats
Old Sep 15, 2009 | 04:51 PM
JPH's Avatar
JPH
Looks like the short stroke/large bore paid off for ous Sean. Congrats on the results. Keep in touch bud.
Old Sep 15, 2009 | 06:02 PM
Fastbird93's Avatar
Definitely Joe. I'm VERY happy they way things came out and that you Nate and I were able to put our heads together on this one. It definitely paid off. Thanks a ton for everything you did for the build man.
Old Sep 16, 2009 | 09:05 AM
RealQuick's Avatar
Awesome Sean! I am happy for you!
Old Sep 18, 2009 | 07:33 AM
smokemup's Avatar
Which turbos are these, 20G or GT35?
Old Sep 18, 2009 | 09:59 AM
Fastbird93's Avatar
20G's, stock APS turbo's.
Old Sep 18, 2009 | 11:17 AM
LS1RedZ's Avatar
Nice numbers. It has to be a handful on the street!
Old Sep 18, 2009 | 11:37 AM
Fastbird93's Avatar
Pretty docile actually. It'll get loose if you let it but it's got very linear power and is surprisingly nice to drive even when getting on it.
Old Sep 18, 2009 | 12:06 PM
Speed Density's Avatar
hashtagBMW
Awesome build and story Sean, I am glad you are enjoying the car now.
Tony.
Old Sep 18, 2009 | 12:31 PM
Fastbird93's Avatar
Thanks Tony!!!!
Old Sep 18, 2009 | 01:16 PM
yonerhottlt1's Avatar
Cotdamn!! Nice numbers especially for a 'mild' street build.
Old Sep 18, 2009 | 03:04 PM
allngn_c5's Avatar
What an impressive setup man. Very low dollar investment with a big dollar return.
What do you think can be done to get those High IAT's down ? If you can't do you intend to lower the boost ?
Whatever you do, have fun and enjoy your car man. Its almost time to put them up.
Sending you a PM
Old Sep 18, 2009 | 03:46 PM
Fastbird93's Avatar
Sending you a PM
I'm thinking about adding in a center mount intercooler and either leaving the twins as be or deleting them. I'm going to try a 70/30 mix first just to see what happens. NOT lowering the boost. It's on a manual controller and that's how I wanted it. Set it and forget it.
Trying to enjoy it but I've had it out once since monday. The kid eats all my time up which I'm fine with. Makes me enjoy the car that much more when I do drive it.
