NEW N/A Trick Flow Head Record
Old Oct 27, 2009 | 12:02 PM
  #41
Fbodyjunkie06's Avatar
Absolutely INSANE! What are the specs on that solid roller sounds like its going to cut off at the end backing it up!?
Old Oct 27, 2009 | 06:02 PM
  #42
Chris05ssTruck's Avatar
Originally Posted by 1badzo
Good luck getting a T-56 to handle that kind of power. Not saying that it cant be done but they sure wont like a 7k dump.
+1...not to mention that it wouldn't be consistant.
Hell, i can't find a clutch to hold my big, mighty powa
Old Oct 27, 2009 | 06:09 PM
  #43
jdiddyws6's Avatar
Considering your setup is WAY more extreme than his, that would make sense.
Old Oct 27, 2009 | 06:19 PM
  #44
Yes....true.....but still.
Old Oct 27, 2009 | 07:41 PM
  #45
stripes1987's Avatar
its a magical cam we came up with its 254/268 .690/.700 on a 112lsa
Old Oct 27, 2009 | 08:49 PM
  #46
1badzo's Avatar
HAHAHAHA
Old Oct 27, 2009 | 08:50 PM
  #47
1badzo's Avatar
Try a stock one that should do it.
Old Oct 28, 2009 | 04:37 AM
  #48
Lil more than that....it's not "1badzo" a stock clutch held that bad **** just fine
Stripes....we ALL know that cam is a magical 220/223 .789.34/943.87 on a 143 LSA
Old Oct 28, 2009 | 09:30 PM
  #49
1badzo's Avatar
Well maybe, but i do know that there are plenty of 400 rwhp cars that have clutches that hold fine i even think there is a car that makes 30 more and is working fine with a 500 dollar clutch, I dont know maybe its you?
Old Oct 28, 2009 | 09:31 PM
  #50
1badzo's Avatar
Sorry back on topic, Chris cont. on swinging.
Old Oct 29, 2009 | 08:09 PM
  #51
Brian Tooley Racing's Avatar
Since Coleman Roddy ran 9.20's with 245's and a HYD ROLLER,
and TXCAMSS ran 9.30's with 235's and a HYD ROLLER,
you MIGHT be #3 on the TFS N/A list
Change that converter and keep after it, I think you'll be #1!
Old Nov 20, 2009 | 06:53 AM
  #52
LS6's Avatar
LS6
Talking
Really Impressive
LSX with potentail of more than +600RWHP with 408ci is insane
MRT
Old Jan 16, 2010 | 02:44 PM
  #53
SIC LSX's Avatar
update! he just put down 675whp with more intake work!
Old Jan 17, 2010 | 12:53 AM
  #54
BAMF's Avatar
Have you driven it on the street LOL that would be fun
Old Jan 19, 2010 | 09:07 PM
  #55
Are the race tracks open down there? I would think you guys should have some good track weather about now!
Old Jan 19, 2010 | 09:09 PM
  #56
SIC LSX's Avatar
yeah its open and nice weather, highs in 60's and lows 50/40's
Old Jan 22, 2010 | 08:21 PM
  #57
i think we are waiting to get the 265's and we are going to try a little more agressive cam as well with doing a new manifold as well and try something a little different.
Old Jan 22, 2010 | 09:52 PM
  #58
syclone2882's Avatar
sounds like some huge #'s
Old Jan 27, 2010 | 04:12 PM
  #59
SIC LSX's Avatar
his motor is 4sale
selling the complete Engine out of his car from oil pan to intake manifold. he is getting the motor for next year's lsx shooutout ready and this engine is not needed anymore.
there are right at 20 passes on it. no street miles.
it has:
trickflow 245 cylinder heads
Jesel Shaft System
Comp Cams Custom Grind Camshaft
Manton 7/16 Pushrods
Jesel Dogbone Lifters
Titanium Intake and Exhaust Valves
408 CI Iron Block
Callies Dragon Slayer Crank
GRP Aluminum Rods
Wiseco Pistons
14.8:1 Compression
Moroso Oil Pan
GMPP Front Mount Distributor Setup
GCRE Fully Ported Super Victor Intake Manifold 4500 Flange
this motor through a th400 5800 Converter 9" 4.56 Gears and a Set of Slicks
made 675rwhp
at 3200lbs it has been 5.86 @117 with a 1.29 60ft on motor there is still some tweaking that needed to be done to the converter so there is good potential for it to get even faster with the right converter and more gear.
for any more information you can contact the shop number is 850 607 6767 and his cell number is 850 529 3571
Old Sep 25, 2012 | 07:54 PM
  #60
The1N_only's Avatar
What all did you have to do to make a 7/16 push rod fit?
