370 and D1SC numbers
Old Mar 18, 2012 | 03:23 PM
LS1RedZ's Avatar
I know this is an old thread, but i was wondering if anybody can tell what might be wrong. Above was my dyno from the last time before this dyno happened below. I only switched my injectors and went to a 2 bar SD tune.
^^My most recent dyno
Old Mar 19, 2012 | 10:12 PM
5w20's Avatar
Is your belt doing a burnout on the pulleys?
Old Mar 21, 2012 | 02:55 PM
LS1RedZ's Avatar
I have asters bracket setup so I'm pretty sure it can't be belt slip.
Old Mar 22, 2012 | 09:54 AM
5w20's Avatar
seems like its "dying" up top.
i think its either a restriction or belt slip. if the belt is old, it could have stretched and causing it to slip.
Old Apr 2, 2012 | 12:30 AM
b4cz2896's Avatar
Dirty air filter? Clogged cats?
Old Apr 10, 2012 | 05:02 PM
Tirefire's Avatar
Do you have a front mount IC and are you still using the stock D-1 elbow (for the filter) or is it the truck one?
Old Apr 10, 2012 | 10:10 PM
garner's Avatar
Damn! You have one bad *** car! I would love to see it!
Old Apr 14, 2012 | 04:11 PM
I8UR4RD's Avatar
swap the filter, belt, get some good fuel from shell, and check for boost leak. also, i am assuming this is the same dyno, if you mentioned it above I did not see it.
Old Apr 16, 2012 | 09:58 PM
Dynospeed's Avatar
Did you log boost? Is it dropping?
