What are dyno tricks?
J/K
A couple things though. We check tire pressure most all the time before running a car.
We'll also pull the elbow off certain cars. BUT, we'll let the owners know. We do it on higher power GTOs, on higher power LT1s. Both, because the elbow is a significant restriction, and being able to show the customer "look what pulling your elbow off did" is both an upsell and a sort of R&D for us. I've seen 25 rwhp pulling an elbow off certain cars.
Is having people sit in the trunk of a high power FI car a dyno trick? After all, it does make more power. It lessens the wheel spin.
I have one of the lowest reading dynos in our area. A loading dynojet. Who cares, its a tuning tool. If the car only made 415rwhp in a 6 speed f-body big fing deal.. it still came damn close to the cam only records first try out with plenty left in the chassis/weather/weight.
Wait, so you don't see a difference between someone sitting in a car trunk to lessen wheel spin and someone fudging numbers with a correction factor?
-Putting 40+ psi in the back tires
-Putting smaller wheels/tires on the rear
-Using aluminum flywheels but not claiming the car has one
There's quite a few other dirty tricks, but I'm not going to post them and give anybody any new ideas.
Sadly, there is a LOT of very well known and respected shops that pull these tricks to inflate numbers for the internet to see.
Basically tricks fall in 2 catgeories: the operator messing with the correction ad the other is when you mess with the car itself (like pulling belts, filter, and putting on wheels/tires that you don't usually use).
i've tried freezing the filter with nitrous before too, but it didnt help
Also, if you shooting for higher peak on a actual nitrous car, waiting to activate the nitrous until higher rpms (say, 6000 on a 6600 pull)will yeild a larger number on a stalled auto car too.
as you can guess, we get bored at the shop sometimes
