What would cause this?
Old Oct 27, 2009 | 09:06 PM
2ktransam's Avatar
Default What would cause this?
Every time I have had my truck on the dyno it has a weird drop right at peak boost. It only does it above 9psi so I guess it could be a few things but I wanted some opinions. Here is my setup and dyno graph.
stock 6.0L
STS kit, FMIC, Meth, TC 76 BB turbo w/.96 housing
z06 cam and valve springs
built 60e by performabuilt and Yank trt3000 stall
This dyno run was at about 13psi and 20 degrees of timing with no knock and the converter unlocked. The truck pulls good on the street and it has ran a best 11.81 on 11psi. Could it be blowing through the converter or trans slipping on the dyno? Any ideas are welcome. Thanks
Old Oct 29, 2009 | 11:08 PM
Fbodyjunkie06's Avatar
valve float.
Old Oct 29, 2009 | 11:18 PM
DeltaT's Avatar
Yep, or a wastegate or blowoff valve problem.
Jim
Old Oct 30, 2009 | 08:26 AM
2ktransam's Avatar
Originally Posted by Fbodyjunkie06
valve float.
I was thinking that too. I'm also thinking that the meth might be blowing out the spark a little too. I closed my plugs down to .28 last night and I'm going to back the meth off a little and see if that helps before I mess with new valve springs.
Old Oct 30, 2009 | 08:27 AM
2ktransam's Avatar
Jim
Can you elaborate? I am not seeing and boost drop or spike, it holds it's boost level nicely.
Old Nov 1, 2009 | 10:29 PM
2ktransam's Avatar
I had it back on the dyno today and it did the same thing again with the tighter plug gap so that wasn't it. It actually falls off right when it reaches full boost and the wastegate opens all the way. Could it be something with the wastegate or deffinitely valve float? It made 540rwhp today at 14psi but at 4800 rpms.
Old Nov 2, 2009 | 10:14 AM
OUTLAWZ RACING's Avatar
what dyno?
Old Nov 2, 2009 | 12:33 PM
2ktransam's Avatar
Originally Posted by OUTLAWZ RACING
what dyno?
Dynojet
Old Nov 8, 2009 | 10:31 PM
1BAD_LS1's Avatar
Restricted User
looks kinda similar to mine....
https://ls1tech.com/forums/dynamomet...raph-like.html
Old Nov 8, 2009 | 10:56 PM
2ktransam's Avatar
Originally Posted by 1BAD_LS1
Yeah, I've been watching your thread to see if you figured it out. I put mine back on the dyno Saturday tried a few things but nothing worked. So far I have tried the following.
pressure tested all piping
pulled air filter
with and without meth
closed gap on my spark plugs to .27
locked the converter for one run to check for slipage
changed my wastegate to vent to atmosphere
Nothing seems to change on the dyno so I'm going to upgrade my springs and change to the 7.425 push rods. My problem gets worse the more I up the boost. At 8-9psi my power peaks and stays flat to 5500 but at 14psi I lose 50rwhp from 5k to 5500.
Old Nov 8, 2009 | 11:13 PM
1BAD_LS1's Avatar
Restricted User
ya it sucks... I think im gonna break down and try new springs when i get the money for them.
What springs are you running? I am running PRC dauls with only 8000 miles on them.
Im really starting to wonder if its the ls6 cam... I posted a link in my thread to a thread in with a bunch of other dyno sheets where ls6 cams were used on several differnent motor setups and they all did the same!
kinda makes me wonder??????
Old Nov 9, 2009 | 07:54 AM
2ktransam's Avatar
I'm using ls6 yellow springs right now. I looked at my dyno sheet again from Saturday and it looks like venting the wastegate to atmosphere did help some.
I read through that post and I don't understand why some people like Parish and WJMark have had great luck with the ls6 cam and a turbo but some people have trouble.
Old Nov 16, 2009 | 09:22 PM
2ktransam's Avatar
I installed PRC duals tonight and they didn't seem to help any. I did a few pulls and my fuel trims didn't change any and it still feels like it struggles above 5k. Any other ideas? could it be a back pressure problem since it is a STS kit?
Old Nov 16, 2009 | 09:29 PM
GMCtrk's Avatar
This is a graph from a TC76 BB .68 AR on a 6.0. It's from the member Stock48. It peaks at like 4500. What size engine do you have? I think the turbo is choked up out top.
Old Nov 16, 2009 | 09:50 PM
1BAD_LS1's Avatar
Restricted User
Intersting...
I have a 5.3, 317 heads, 02 z06 cam, 7.425 pushrods (around 8.5:1 compression)
turbo is a MPT70/.96AR
Old Nov 16, 2009 | 10:05 PM
2ktransam's Avatar
I have a stock 6.0L with the z06 cam. I do have the .96 exhaust housing on my turbo and I think that dyno was with a smaller AR but you might be right. I wish I understood compressor maps so I could figure out if I am pushing to much air flow for this turbo.
Old Nov 16, 2009 | 10:16 PM
1BAD_LS1's Avatar
Restricted User
Hey man im sorry... i was thread hijacking above. may bad, just realized i replied like that in a post that wasn't mine, lmao!
So you changed valve springs and it didn't help, now maybee i wont change valvesprings. This **** is driving me crazy!
Old Nov 16, 2009 | 10:21 PM
2ktransam's Avatar
That's cool man. I think we might be chasing the same problem. I hope you figure it out so I can stop spending money. This is driving me crazy.
Old Nov 16, 2009 | 10:41 PM
1BAD_LS1's Avatar
Restricted User
LMAO here i am hoping you will figure it out, so i can stop wasting my time and money!!!!
lol, i figure mine out youll be the first person to know!!!
Old Nov 16, 2009 | 11:26 PM
GMCtrk's Avatar
You may want to look into the TC78 BB 1.15 AR. That should give you more up top. That's the turbo I've got my eye on for my 6.0. I don't want to fall into the same trap you guys did. I want super quick spool and great pull up to 6k rpm.
