Crappy Dyno...What could it be?
here are my mods and cam specs
99' Ls1 w/ARP Rod Bolts, Ported LS6 Oil pump, LH8 Hummer Oil Pan, BRP Engine Mounts
Stg 2ish early model (243)Z06 heads, Patriot Gold springs w/Titanium Retainers, Ferrea Race Valves, Factory Rocker Arms, Comp Lifters, TSP Pushrods (flow 314cfm@.600)
Victor Jr Carb Intake w/Edelbrock 750cfm Carb, Summit High Performance Electric Fuel pump & Regulator, 16gal Fuel Cell in Trunk, Jegs Billet Fuel Filters, Steel Braided Fuel Lines
Futral Custom Cam 236/240 112+4 (.641/.612 lift)
Vette Assc. Only using AC and Alt
4000 Nitrous Stall/ TH350
3.73 gearing
timing was set at 30 degrees, we tried 32 & 33 and lost power, also tried 28 intialy and it did 326rwhp. Low number is 1st dyno with timing set at 33 degrees
HEAD Flow Numbers
0.200 148 114
0.300 206 153
0.400 255 178
0.500 295 202
0.600 314 212
0.700 319 218
I still think the carb may be a bit small on your combo. After that, it comes down to how good the heads really are. Flow numbers are not everything and I've seen more than one set of LS6 heads destroyed by a porter who isn't familliar with LSx style heads.
Shane
). I bet I can get 380-390 @ wheels on that combo atleast. A 750 is PLENTY of carb for that motor. Even without a wideband I can still tune it with a few jet changes and the old spark plug method. 72's in front, 76's in the rear it's what my guess is.
Are you running the 6010 box?
My old carbed LS1 Coupe only put down 396rwhp through a TH350, 4.10 gears and still managed 6.72 @ 102 all motor. Give me a shout, I'll be glad to help.
Tuning a carb setup makes a HUGE difference. When I first got it going, I ran 7.32 @ 97mph. After I tuned it and changed a few things I busted off the 6.72 and it was consistant.
That's alot of difference.. 370rwhp vs 450'ish with an m6. D- any #'s out of autos with that cam?
