408 with Trickflow 220 as-casts - 04 A4 GTO
Dyno'd her today with only 40 miles on the new motor. I'm sure she will only get better with age.
11.76:1 compression
Iron LQ4
4.030 bore
4.00" Stroke
Wiseco pistons (-8cc)
Eagle rods (6.125")
K1 (Carillo) Crank
All ARP hardware
Trickflow 220cc heads (As-cast - 62cc - 4.0" bore)
Yella Terra 1.7 roller rockers
LS7 lifters
Comp Cams 239/247 .624/.624 112+0 LSA
7.500" pushrods
Cometic .040 gaskets
All assembly done by yours truly.
1 3/4" Kooks headers
Magnaflow exhaust
off-road midpipes
K&N Intake for 04 GTO (HUGE RESTRICTION ! ! ! ! !)
FAST 90/PTM90
HPTuners tune - by ME
Final Dyno numbers:
475RWHP
490RWTQ
Will probably look into a bigger maf and intake tube to see how much she picks up. It was showing 96KPA at WOT which is a dead indicator of an intake restriction.
I just wanted add a huge thanks to Oak200 on LS1GTO.com (Paul) and JMantis here on LS1TECH (Jim) for their invaluable assistance with the actual motor swap. No way could I have done it without them. Two weekends in a row without a complaint and all the encouragment a guy could ask for. Also another thanks to Oak200 for helping with the pre-assembly. And of course, let's not forget Hardcore for helping me with the wideband and for all the myriad tuning/engine build conversations we have had.
11.76:1 compression
Iron LQ4
4.030 bore
4.00" Stroke
Eagle rods (6.125")
K1 (Carillo) Crank
All ARP hardware
LS7 lifters
7.500" pushrods
Magnaflow exhaust
off-road midpipes
FAST 90/PTM90
Final Dyno numbers:
475RWHP
490RWTQ
congrats. gotta admire anyone who does their own build. Ed from VA Speed would tell you to "get rid of the elbow". might want to consider eliminating the MAF and going SD, although i know there are differences of opinion regarding that.
"Will probably look into a bigger maf and intake tube to see how much she picks up. It was showing 96KPA at WOT which is a dead indicator of an intake restriction."
What value(s) should the MAP have during WOT? During the whole WOT rpm range should that value be the same? Does that value vary with engine size?
It would be nice to get rid of the elbow though, I just don't like the current OTR offerings.
Nice numbers! I am shooting for at least 475 this Friday when SNL installs one of their 4" CAI's and retunes the car. I won't be anywhere near that torque though.
The smaller headers might be holding you back some there also.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
11.76:1 compression
Iron LQ4
4.030 bore
4.00" Stroke
Eagle rods (6.125")
K1 (Carillo) Crank
All ARP hardware
LS7 lifters
7.500" pushrods
Magnaflow exhaust
off-road midpipes
FAST 90/PTM90
Final Dyno numbers:
475RWHP
490RWTQ
11.76:1 compression
Iron LQ4
4.030 bore
4.00" Stroke
Eagle rods (6.125")
K1 (Carillo) Crank
All ARP hardware
LS7 lifters
7.500" pushrods
Magnaflow exhaust
off-road midpipes
FAST 90/PTM90
Final Dyno numbers:
475RWHP
490RWTQ
Very nice power from A4...
Congratulation
Finally got her to the track.
first run was a spin fest.....so was the second.
Third pass was a 11.34@121
backed up by a 11.38@120.7 and an 11.35@120.85
Next up I guess will have to be a bigger stall. 2200 RPM launches are just funny compared to my 3600 stall in the old car. Still managed a trio of 1.5x sixty foots (best in the old car was a 1.63), but I'd love to see a 1.4x
