Should I be happy with these numbers?
LT/ORY/Mag cat back
ported stock throttle body/
smooth bellow/slp underdrive pulley
slp lid/ Patriot performance ls6 style stage 3 (i know these arnt really for our ls1 stock bore and cubic inch) Comp cam Si4 228/228 113 LSA .588 lift
Made 425 Hp to the tires and 393 torque.
On the bottle it made 590 hp and 585 tq
Its a dry shot with jet size .068 about 165 shot
Think I should be happy with those numbers? And should i up the shot to get over 600 lol.
Ask the shop to put it on "SAE Smoothing 5" and send you the numbers. Usually it will read lower with a higher smoothing, and STD reads higher period. SAE is industry standard now a days.
Im not discrediting your numbers, but if you want to really compare it with most other peoples setups more accurately, you should be looking at a smoothed power curve.
Either way though, as long as it feels good and runs hard, that all that matters in the end.
13.6:1 AFR is pretty close to the edge as 69LT1Bird was saying. Did that shop tune you also? I would start scratching my head right about now if I were you.
[/IMG]
