Are full bolt-ons worth 100 rwhp?
Raceweight hasn't changed and the mileage is now 146k. I know the ls1s get stronger with miles but ...
I thought every mph is worth 10 hp.
Most quarter mile calculators say that my car at 3000lb race weight which is what it is I should need 400+ whp to run the quarter mile times I did with a stock ls1 with exhaust and ported TB. Putting out good numbers but still a reasonable 335 whp
I would not put 100% faith in those estimated HP calculators. A lot of assumptions. For fun, you can always hook a a G-Tech device (or similar) and just go with the concept of 'net horsepower'. The numbers will humble you, but it is in actuality a pretty valid way of calculating 'to the road' HP.
Hope that helps.
..WeathermanShawn..
My car also made 296 when stock. It trapped 104 mph. I only have bolt ons now as well and my last dyno was 354rwhp. Now I trap 115+ in similar air. My car weighs about 150-175 lbs less now than stock.
I think your car is 'overachieving' because it has better gearing, more power under the curve, and you're probably better at driving the car now than when you first got it.
..Google search..
Solving for engine horsepower using the trap speed method.
Remember, getting good air is an huge advantage. Our track (Bandimere) is at 5800', with DA's running 7000+, depending on temperature. I trap at 110.5 mph with my setup. The calculators always seem to overestimate my HP also.
Perhaps someone can share if they have a different formula, or a better way to estimate HP by Trap Speed.
..WeathermanShawn..
Also thhink about your headers, even though they may only get you 20hp, they also save weight.
Don;t always look at hp peak numbers. Lets say you have a car that makes 370hp @ 6,000 rpm. Now take that same car and put a bigger cam in it...now 400hp At 6,400 rpm. even though you only gained 30 hp from peak numbers, the differenve at 6400 now vs 6400 then may be 50hp since the other cam started falling off and not pulling harder for longer. this is what happened after my cam swap.
I thought I gained only 30 hp, but the car somehow went from 11.5 @ 117 to a 10.9 @ 123. looking at the dyno sheet befroe and after, the difference was 60hp at 6,400 rpm, giving my the 6 mph and .6 in the 1/4.
your car may only have gained 40rwhp, but now that you have gears, and the difference at 6,000 may be greater then 40hp.
Get the car dynoed again and look at the old sheet or overlap them if you can.
