460cid LSX
Just a short vid of my 460 LSX idling on the engine dyno. 13:1 compression, Callies Magnum Crank, Callies Rods, Ross Custom Pistons, ETP C5R 265 heads, Jesel Pro Stock Rockers, 900+ lift 320+ duration Cam. ARE 3 Stage Dry Sump, Beck Custom Intake, RevXtreme Custom Billet 105mm Throttle Body, BigStuff 3 EMS. Put down 765HP@7100 RPM's and 576 Ft/Lbs@6200 RPM's on a FATASS tune. Once it's in the car, We should have it over 800HP easy. It can idle under 1000RPM's and purrs like a kitten.
Nitrous setup from my friend Nitro Dave capable of spraying 3 stages up to 1500HP. Won't use it until the car is well track tuned NA.
Thanks to Randy at PER Race Engines and Don Bailey!
http://www.youtube.com/watch?v=FfuVxbjr8Ho
The motor was built for spray but I figure I won't spray more than 500 or so. The initial tune is a really simple one only for testing. it spins up to 9500 RPM's in no time. Probably launch it at 8500 NA and 9k or more on the spray.
